precompiled binary: Unhandled 'written' exception in NTDLL?
mapserv40, windows 2k/XP IIS/Apache
Carsten M ünchenbach
map at HYDRARGYRUM.DE
Mon Feb 7 04:35:07 EST 2005
Hi everybody,
Ed, thanks for your reply,
I installed the ws4w package on an windows xp system - it worked.
Then I took the mapserv_44.exe from the current ws4w-package and overwrote
the mapserv.exe distributed as the current windows binary - it works!
As far as I can see the mapserv.exe has been corrupt.
Carsten
>Carsten -
>I do not recognize this problem, but the three symptoms you list (mapserv
-v runs fine, "premature end of script header" message, and no temp file)
are commonly caused by lack of access to zlib.dll. Make sure that file is
installed and someplace MapServer can find it.
> - Ed
>Ed McNierney
>TopoZone.com
>-----Original Message-----
>From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Carsten Münchenbach
>Sent: Sunday, February 06, 2005 5:15 PM
>To: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: [UMN_MAPSERVER-USERS] precompiled binary: Unhandled 'written'
exception in NTDLL? mapserv40, windows 2k/XP IIS/Apache
>Hi everybody,
>I've downloaded the windows binary version 4.4.1 and installed in on a
>windows xp system with IIS 5.0 and also on a windows 2k system with Apache,
>the web root is in both cases not on the C: partition, the cgi-bin directory
>is on the C: partition. In both cases I got everything installed including
>the workshop. But when running the workshop and hitting the "Initialize"
>button I'm running into an unhandled exception about problems with "it can
>not be written in memory ..." When starting the visual c++ debugger it shows
>that the exception comes from the NTDLL.dll. First I thought it doesn't work
>because of insufficient access rights to the temporary image directory of
>the I_USR. But I get the same error in an Apache environment.
>- running the mapserv.exe on the DOS-prompt looks fine
>- the apache error file gives only the "premature end of script header" message
>- auditing of unsuccessful object access in windows XP shows no trial to
>access to the tmp directory (no error entry in the event viewer) - I think
>the exeption comes up before.
>Did anyone experience that error before? Does anyone can give me a clue or
>even a solution?
>Thanks to all
>Carsten
