WFS GetFeature and PropertyIsLike Filter
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Mon Feb 7 17:07:45 EST 2005
Tom,
I just tried mapserver cvs with my test data and It seems to work. I
would need data/map file from you to work on this (either directly to me
or even better through a bug).
Later,
Kralidis,Tom [Burlington] wrote:
> Hi,
> I am able to run a GetFeature on a given feature type with filter
> PropertyIsEqualTo:
> http://devgeo.cciw.ca/cgi-bin/mapserv/eccat?version=1.0.0&service=WFS&re
> quest=GetFeature&typename=service_endpoints&filter=<Filter><PropertyIsEq
> ualTo><PropertyName>contact_country</PropertyName><Literal>Canada</Liter
> al></PropertyIsEqualTo></Filter>&
> When I attempt to run with filter PropertyIsLike:
> quest=GetFeature&typename=service_endpoints&filter=<Filter><PropertyIsLi
> ke wildcard="*" singlechar="."
> escape="!"><PropertyName>keywords</PropertyName><Literal>*water*</Litera
> l></PropertyIsLike></Filter>&
> I get no results back.
> When I re-attempt the PropertyIsLike request with no wildcards in the
> Literal:
> escape="!"><PropertyName>keywords</PropertyName><Literal>water</Literal>
> It works. So then I think that the PropertyIsLike attributes are not
> needed since the previous command works. When I run it:
> ke><PropertyName>keywords</PropertyName><Literal>water</Literal></Proper
> tyIsLike></Filter>&
> It doesn't work.
> I'm confused. The attributes or PropertyIsLike seem to be required to
> execute, however they don't work when applied?
> ..Tom
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
