extent is invalid for geotiff
Ed McNierney
ed at TOPOZONE.COM
Tue Feb 8 09:41:26 EST 2005
John -
No, there isn't any preferred method. A GeoTIFF will hold projection,
datum, and bounding box information in a way that can be read by
MapServer. As long as the GeoTIFF is created properly (i.e. you can't
leave out the projection) the coordinate formats used don't matter.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of John Bonk
Sent: Monday, February 07, 2005 11:39 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] extent is invalid for geotiff
Ed,
Thank you, that worked. I seems obvious now when I look back at the
documentation.
Perhaps someone can answer another question. In creating geotiffs, is
there a preferred way of specify coordinates (degrees, UTM, etc) so
that the image will work well with MapServer?
Thanks again for the response,
John
At 23:10 2005-02-04 -0500, Ed McNierney wrote:
>John -
>If that's the only data layer in your map, ignore PROJECTION
>completely, at least for now.
>Have you tried an EXTENT of:
>EXTENT -13053641.3 3358256.867 -932579.471 5752577.812
> - Ed
>Ed McNierney
>TopoZone.com
>On Behalf Of John Bonk
>Sent: Friday, February 04, 2005 5:08 PM
>Subject: [UMN_MAPSERVER-USERS] extent is invalid for geotiff
>I am very new at this. I am having problems serving a geotiff image
>with the following attributes:
>Projection Method: CT_Equirectangular
> ProjCenterLatGeoKey: 0.000000 ( 0d 0' 0.00"N)
> ProjCenterLongGeoKey: 0.000000 ( 0d 0' 0.00"E)
> ProjFalseEastingGeoKey: 0.000000 m
> ProjFalseNorthingGeoKey: 0.000000 m
>Corner Coordinates:
>Upper Left (-13053641.300,5752577.812)
>Lower Left (-13053641.300,3358256.867)
>Upper Right (-9325729.471,5752577.812)
>Lower Right (-9325729.471,3358256.867)
>Center (-11189685.386,4555417.340)
>I have tried all sorts of variation of these number in the EXTENT field
>but I have been getting an 'extent is invalid' message.
>Can anyone help me express the EXTENT and PROJECTION to read this file?
>John
>John Bonk
>SSAI/NASA GES DISC
>Phone:(301) 614-5280
>Fax: (301) 614-5268
>For more information about
>the NASA GES DISC and its services:
>http://daac.gsfc.nasa.gov/
John Bonk
SSAI/NASA GES DISC
Fax: (301) 614-5268
