showing lines of overlapping polygons {Scanned} {Scanned}
Siki Zoltan siki at AGT.BME.HU
Wed Feb 9 10:38:04 PST 2005
Change the COLOR for the class to -1 -1 -1, then you will see all the
border lines, but you will not know which belong to the same polygon.
Overlapping polygons in the same layer make you hadache using any GIS
software. Try to avoid it.
Bye
Zoltan
On Wed, 9 Feb 2005, Erwin v.d. Bij wrote:
> Hello,
> I want to see the lines of 2 or more polygons which do overlap. Polygons are in the same layer. Polygons are filled with a style. Currently, I see only all the lines of the polygon which is obvious on top. I've experienced with the TRANSPARANCY attribute, but that did not help. Do you have any ideas?
More information about the MapServer-users mailing list
