Mapserver bug?
Murilo Lacerda Yoshida
murilo.yoshida at AGX.COM.BR
Wed Feb 9 12:17:58 EST 2005
Hi all,
I have the same problem as Jeff, but I am NOT using mapscript pre-loaded, and
I'm lost... I saw the bug, the last post on it said that there was reports that
that bug was still happening on mapserver 4.4 period.
What to do? I'm thinking in changing my php back to cgi and wait the bug to be
solved ... But I'm not yet sure that this is a mapserver bug ... everything
points to it, but could be something else...
Thanks,
Murilo
I've fixed the problem now, thanks very much for the pointer to that bug. I am
running php as a module as you said, however if I try to run in CGI mode I get
a mapscript error saying that this build can't run in CGI mode
due to stability issues. So I have no choice but to run it as a module.
However, I read the bug report you gave me and somebody reported that hte
problem went away if you did not pre-load mapscript.so in your php.ini. Others
said that the problem persisted either way, but I gave it a try myself... I
took out the extension=php_mapscript.so line out of my php.ini and added the
"ld php_mapscript.so" line to my scripts and now they work perfectly.
Thanks very much!
Jeff
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Wednesday, February 09, 2005 1:47 AM
Subject: Re: [UMN_MAPSERVER-USERS] Mapserver bug?
> hi jeff
> youare probably using php as a module ... see bug-id 67.
> Mit freundlichem Gruss / Best Regards
> Flavio Hendry
> TYDAC NEWS http://www.tydac.ch/german/index.php?menu=News_actual
> ############ Mit freundlichen Gruessen / Kind Regards
> ############ mailto:flavio at tydac.ch
> ############ TYDAC AG - http://www.tydac.ch
> #### #### Geographic Information Solutions
> #### #### Luternauweg 12 -- CH-3006 Bern
> ############ Tel +41 (0)31 368 0180 - Fax +41 (0)31 368 1860
> -----Original Message-----
> From: Jeff Portwine <jdport at VERITIME.COM>
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Date: Tue, 8 Feb 2005 13:59:38 -0500
> Subject: [UMN_MAPSERVER-USERS] Mapserver bug?
>> I'm pretty sure that this issue i'm having was posted about once
>> before a week or two ago by somebody else, but there wasn't much
>> response to it and I'm not sure if it is a mapserver bug, or
>> something I'm doing wrong, or if there is a workaround for it.
>> When my map form submits and is redrawn according to whatever buttons
>> the user has clicked (panning buttons, zoom, etc) it will sometimes
>> jump back to an old image instead of displaying the image it is
>> supposed to be showing. If you then just click refresh in the
>> browser, it displays the proper image. At first I thought it was
>> some kind of browser caching issue, so I tried all the meta tags and
>> http headers I could find to disable the caching of images in my
>> application... but that didn't fix the problem. The problem also
>> seems to be browser independant as I see the same behavior in
>> internet explorer and Mozilla firefox. It also seems to get
>> worse over time... when I first load up the browser and go to the web
>> page it will work perfectly for a little bit, but after a short time
>> it will start showing old images and eventually it will start doing
>> it almost every refresh.
>> Have any others had this kind of problem, and has anybody found a way
>> to fix it or avoid it?
>> Thanks for any advice,
>> Jeff
