mapserv segfaults
John C Cartwright
John.C.Cartwright at NOAA.GOV
Fri Feb 11 11:05:12 EST 2005
Hello Frank,
thanks for your suggestion, it seemed to be the key. I removed the
"--with-tiff" argument to mapserver config and recompiled GDAL and
mapserver. Seems to work fine now. When I get a chance, I'll go back
and see if I can add the SDE support back into mapserver.
Thanks again to you and the others on the list for all the help!
-- john
Frank Warmerdam wrote:
> On Thu, 10 Feb 2005 13:57:58 -0700, John C Cartwright
> <John.C.Cartwright at noaa.gov> wrote:
>>Any ideas on what I should try next? I specified
>>--with-libtiff=internal --with-geotiff=internal in the GDAL config. If
>>I specify a --with-tiff=DIR in the mapserver config, is that library
>>used or the one in the GDAL config?
> John,
> Generally speaking if you are using GDAL there is no reason to use
> the --with-tiff option for MapServer. The built-in use of libtiff is not
> nearly as flexible as using it through GDAL.
> If you build MapServer --without-tiff and if nothing else drags in
> libtiff other than GDAL then you should be ok. If something else
> is dragging in libtiff, then ensure you build GDAL to use the same
> libtiff rather than it's internal copy.
> The key is to configure things to ensure there is only one libtiff
> or your life can be hell.
> Best regards,
