SIZEUNITS in Perl Mapscript
Lowell Filak
lfilak at MEDINACO.ORG
Tue Feb 15 08:56:19 EST 2005
The following message was sent by Agneta Schick
<schick at SDAC.HANNOVER.BGR.DE> on Mon, 14 Feb 2005 17:11:07 +0100.
> Problem: symbol size doesn't scale
> Software: MapServer version 4.2.3, Perl MapScript
> Is my understanding of SIZEUNITS correct?:
> I can define SIZEUNITS to kilometers, define a symbol 'circle'
> and by setting the symbol size to my radius (in kilometers),
> this symbol will scale to my zoom depth?
> My symbol always has the same pixel size as if SIZEUNITS uses the default
> PIXELS.
> I checked the user group mails but found no clue, except that other users
> also had problems.
> The layer in question is
> LAYER
> NAME 'percept'
> TYPE point
> STATUS on
> PROJECTION
> "proj=latlong"
> "datum=WGS84"
> END
> SIZEUNITS kilometers
> CLASS
> STYLE
> SIZE 1
> SYMBOL 'circle'
> OUTLINECOLOR 0 0 240
> END
> END
> END
> and the perl snippet:
> $layer = $map->getLayerByName('percept');
> $class = $layer->getClass(0);
> $style = $class->getStyle(0);
> $style->{size} = int($radius);
> $point = new mapscript::pointObj();
> $point->{x} = $lon;
> $point->{y} = $lat;
> $point->draw($map, $layer, $img, 0,0);
> I appreciate any help in this matter since 'racking my brain' doesn't help
> me at all!
Agneta,
If I'm understanding things correctly, sizeunits effects the 'class'
size and not the 'style' size.
Lowell
