ogr2ogr
AJ Kertis
akertis at GMAIL.COM
Tue Feb 15 13:35:18 EST 2005
That Command worked great for getting the information i needed. I just
don't know how to do something like that so my CompleteChain.shp that it
creates with ogr2ogr has what i did with -where 'fetype. It gives me a
message about
Error 1:Failed to identify field:fetype
So i'm not sure how i type this differently to get it to work with
ogr2ogr.
Thanks again,
AJ Kertis
On Mon, 2005-02-14 at 21:23 -0500, Frank Warmerdam wrote:
> On Mon, 14 Feb 2005 16:53:41 -0500, AJ Kertis <akertis at gmail.com> wrote:
> > Hi,
> > I'm trying to fiddle with ogr2ogr. I can convert the tgr files to shp
> > files fine. I just was wondering how the -where flag is supposed to
> > actually work. Like in my CompleteChain.shp file i have some field types
> > of fetype and i want to do ogr2ogr so that one type in there isn't in
> > the .shp file from the tgr file if that makes sense. Is this possible
> > with ogr2ogr?
> AJ,
> The following query just reports non-"St" features from the
> completechain layer. You should be able to use a similar constraint
> with ogr2ogr.
> ogrinfo -ro tst25023.rta CompleteChain -where 'fetype <> "St"'
> Best regards,
