Loading information from postgresql
Astrid Emde
astrid.emde at CCGIS.DE
Wed Feb 16 02:54:03 EST 2005
Hello Carlos,
if you don't want to show the whole table but only a query in your map
you have to write DATA like this:
1. you can write the query in the DATA-Parameter:
DATA "the_geom from (select oid, gid, name,pc,number from plz where
pc=1) as foo using unique gid using SRID=4326"
2. You can make a query/view in postgresql and refer to the query:
DATA "the_geom from (select * from qry_wfs_plz) as foo using unique gid
using SRID=4326"
More information about PostGIS and umn MapServer you can find on the
postgis-homepage:
http://postgis.refractions.net/docs/ch04.html#id3370572
Good luck
Astrid
Carlos Eduardo Sibaja Salazar wrote:
> Hi. I installed postgresql, postgis and mapserver.
> Now i can load maps from the database and show this maps with mapserver
> in a browser.
> I'm using this line to do it: DATA "the_geom from mytable"
> I can see the map. But now i want to show an specific information. For
> example, i have information about all the towns in my country, and i
> want to show in the map only some towns, using a "where" sentence.
> Something like DATA "the_geom from mytable where ..."
> Please tell me if someone knows a good tutorial or guide where i can
> learn to do this.
> Thanks.!!
> _______________________________________
> Yo me registré en www.costarricense.cr
Mit freundlichen Grüßen
Astrid Emde
Astrid Emde
CCGIS GbR
Siemensstraße 8
53121 Bonn
Germany
astrid.emde at ccgis.de
www.ccgis.de
Tel.: ++49 (0) 228 90826 19
Fax.: ++49 (0) 228 90826 11
Zentrale: ++49 (0) 228 90826 0
