'PVALUE' error with PROJ4 when building PHP MapScript??
Frank Warmerdam
fwarmerdam at GMAIL.COM
Thu Feb 17 11:22:02 EST 2005
On Thu, 17 Feb 2005 08:38:54 -0600, Bob Bruce <covariance at shaw.ca> wrote:
> I have been trying to build the nightly build of MapServer, specifically
> PHP MapScript with PHP5 on a WIN2K system and have just got an error on a
> link that has me stumped and am wondering if someone can help me - please?
> The error is:
> C:\Program Files\Microsoft Visual Studio\VC98\include\winreg.h(88) : error
> C2371: 'PVALUE' : re
> definition; different basic types
> c:\projects\proj-4.4.9/src\projects.h(178) : see declaration
> of 'PVALUE'
Bob,
I believe you need USE_PROJ_API_H defined (ie. -DUSE_PROJ_API_H
in CFLAGS) so that MapServer won't use the old projects.h file. It
should be using proj_api.h which avoids conflicts with Win32.
Perhaps this should be put into the makefile that builds the php stuff?
On second thought, I have stripped out this test completely in the 4.5
source tree. We don't need to support ancient versions of PROJ.4 anymore.
If changing your local makefile is a problem, just add the following at
the very beginning of mapproject.h:
#define USE_PROJ_API_H
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
