WMS layer in 4.4.1
Howard Butler
hobu at IASTATE.EDU
Thu Feb 17 15:45:50 EST 2005
Can you define a "wms_extent" member in the METADATA? There is a bug in
4.4 where if that member isn't defined, the raster machinery tries to
"open" the layer to find the extent.
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1118
Howard
At 02:38 PM 2/17/2005, Brian Fischer wrote:
>This is a multi-part message in MIME format.
>------_=_NextPart_001_01C51530.B0F6D891
>Content-Type: text/plain;
> charset="US-ASCII"
>Content-Transfer-Encoding: quoted-printable
>I was wondering if anyone else had this problem. I was using MapServer
>CGI 4.2.1 binary I downloaded from the MapServer site and my WMS layer
>worked fine.
>=20
>I tried to upgrade to the MapServer 4.4.1 binary on
>http://hobu.stat.iastate.edu/mapserver/ and now my WMS layer doesn't
>show up. It doesn't give me any errors either. I did a mapserv.exe -v
>command on the binary and it says it has WMS Client Support. It's
>creating an 110867242220280.img.tmp file in my temporary images folder,
>but it is 0 bytes. Has something changed in 4.4.1? Or is the binary
>possibly bad? Everything else seems to work fine.
>=20
>Here is my layer definition:
>LAYER
> NAME aerialphoto
> METADATA
> "wms_title" "USGS Digital Ortho-Quadrangles"
> "wms_srs" "EPSG:26914" #NAD83 UTM zone 14N
> LYRNAME "DOQs (orthophotos)"
> LINK
>"http://terraserver.microsoft.com/about.aspx?n=3DAboutTerraServiceOvervie=
>w"
> END
> STATUS ON
> TYPE RASTER
> MINSCALE 1500
> MAXSCALE 80000
> CONNECTIONTYPE WMS
> CONNECTION
>"http://terraservice.net/ogcmap.ashx?VERSION=3D1.1.1&SERVICE=3Dwms&LAYERS=
>=3DDO
>Q&FORMAT=3Dpng&styles=3D"
>END
>=20
>Thanks for any help,
>Brian
>Content-Type: text/html;
> charset="US-ASCII"
>I was wondering if anyone else had this = problem. I was using MapServer
>CGI 4.2.1 binary I downloaded from the MapServer site = and my WMS layer
>worked fine.
>I tried to upgrade to the MapServer 4.4.1 binary on =
><3d.htm>http://hobu.stat.iastate= .edu/mapserver/ and now my WMS layer
>doesnt show up. It doesnt give = me any errors either. I did a
>mapserv.exe v command on the binary = and it says it has WMS Client
>Support. Its creating an = 110867242220280.img.tmp file in my temporary
>images folder, but it is 0 bytes. Has = something changed in 4.4.1? Or
>is the binary possibly bad? Everything else = seems to work fine.
>Here is my layer = definition:
>LAYER
> NAME aerialphoto
> = METADATA
> "wms_title" "USGS Digital = Ortho-Quadrangles"
> "wms_srs" "EPSG:26914" #NAD83 UTM zone = 14N
> LINK =
> "http://terraserver.microsoft.com/about.aspx?n=3DAboutTerraServiceOv= erview"
> = END
> STATUS = ON
> TYPE = RASTER
> = MINSCALE 1500
> = MAXSCALE 80000
> = CONNECTIONTYPE WMS
> = CONNECTION
> "http://terraservice.net/ogcmap.ashx?VERSION=3D1.1.1&SERVICE=3Dw=
> ms&LAYERS=3DDOQ&FORMAT=3Dpng&styles=3D"
>END
>Thanks for any = help,
>Brian
>------_=_NextPart_001_01C51530.B0F6D891--
