map projection problem
Indictrans Team
indictrans at FASTMAIL.FM
Mon Feb 21 08:43:02 EST 2005
Dear Sir,
We have installed Mapserver-4.4.1 on Debian Knoppix version 3.4, Apache
version 1.3 with support for PostGIS. We have ESRI shapefile named
maharashtra.shp which is located in /var/www/tmp/ . Below is a mapfile
that we have created to display this shapefile.
MAP
NAME TEST
STATUS ON
DEBUG ON
IMAGETYPE PNG
SIZE 800 500
SHAPEPATH "/var/www/tmp"
FONTSET "font.txt"
EXTENT 60 50 4270 4480
UNITS METERS
IMAGECOLOR 240 240 240
PROJECTION
"proj=lcc" "lat_1=32" "lat_2=44" "lat_0=38" "lon_0=-100"
"x_0=0" "y_0=0" "ellps=GRS80" "datum=NAD83"
END
WEB
IMAGEPATH "/var/www/tmp/"
IMAGEURL "/tmp/"
LOG "/var/www/tmp/log.txt"
END
# LAYER
# NAME "Nighttime lights"
# TYPE RASTER
# STATUS ON
# DATA "/var/www/tmp/maharashtra.shp"
# END
LAYER
NAME "credits"
STATUS DEFAULT
TRANSFORM FALSE
TYPE ANNOTATION
FEATURE
POINTS
20 400
END
TEXT
'नमस्ते,
आपले
स्वागत
आहे'
END
CLASS
NAME 'AREA'
COLOR 202 1 2
LABEL
TYPE truetype
FONT Gargi
ENCODING UTF-8
SIZE 20
POSITION CR
COLOR 0 0 0
END
END
END
LAYER
NAME "boundaries"
TYPE POLYGON
STATUS ON
DATA "maharashtra"
#COLOR 233 342 123
PROJECTION
"proj=latlong"
"ellps=GRS80"
"datum=NAD83"
END
CLASS
NAME "US states"
OUTLINECOLOR 122 234 50
COLOR 255 255 0
SYMBOL 0
END
END
END
We have kept this mapfile in /home/indictrans/gis/mapserverdocs/workshop
. When we run this file using the following URL:
http://localhost/cgi-bin/mapserv?MODE=map&MAP=/home/indictrans/gis/mapserverdocs/workshop/font.map&layer=boundries
We get only the text layer ( Unicode characters) on the output screen
but the image of maharashtra map (ie the shape file of maharashtra ) is
not
displayed and there is no error message also.
It is because of values of projection parameters and the extent values
of map? If yes what it should be?
Please help us in overcoming this problem as soon as possible.
with regards
Supriya
Indictrans Team
