OGR security issue
Tim Mackey
Timothy.Mackey at GA.GOV.AU
Thu Feb 24 21:44:37 EST 2005
We were unsuccessfully trying to publish a new mapserver application using
OCI connections via GDAL. We eventually got it to go, but during our testing,
the following error message was visible in a web browser:
msDrawMap(): Image handling error. Failed to draw layer named 'xxxxxxxx'.
msOGRFileOpen(): OGR error. Open failed for OGR connection
`OCI:USER/PASSWORD at DATABASE'. File not found or unsupported format.
The fact that the Oracle password is displayed in the error message sent to
the browser is clearly a security risk. I therefore modified the code in
mapogr.cpp, so that the password was replaced in the error message be a
series of '*' characters.
It has worked for me. Would a kindly developer put this code into CVS for the
next release?
Around line 850 in version 4.2.0 of mapogr.cpp:
char maskpasswd[MS_MAXPATHLEN];
int i,passwd=0;
strcpy(maskpasswd,pszDSName);
for(i=0;i<strlen(maskpasswd);i++)
if(passwd)
if(maskpasswd[i]=='@')
break;
else
maskpasswd[i]='*';
if(maskpasswd[i]=='/')
passwd=1;
msSetError(MS_OGRERR,
(char*)CPLSPrintf("Open failed for OGR connection `%s'. "
"File not found or unsupported format.",
maskpasswd),
"msOGRFileOpen()");
Many thanks,
Tim Mackey
Web Systems Manager
Geoscience Australia
02 6249 9813
timothy.mackey at ga.gov.au
http://www.ga.gov.au/
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050225/107f7a41/attachment.html
