Image Resolution
Holger Flörke
floerke at DOCTRONIC.DE
Fri Feb 25 07:23:33 EST 2005
Hi Benoît,
I was faced with the same task: rendering high resolution images of maps
for printing. The "resolution" value within the mapfile is only for the
computation of the scale necessary. I ended with a php/mapscript script
that increases the pixel width and height of the map and increase also all
size/minsize/maxsize values of the map before drawing.
The result is a *big* gif-image. The last drawback is, I couldn't set the
right resolution to the image.
HolgeR
Benoît Toutain schrieb:
> Hi,
> It's just to print my images on a pdf file with a good quality.
> When I change resolution propetry of the map object before doing a
> $map->draw() , it does not work
> (I use mapssever 4.2.5)
> Benoît
holger floerke d o c t r o n i c
email floerke at doctronic.de information publishing + retrieval
phone +49 2222 9292 90 http://www.doctronic.de
