PHP/Mapscript Crash...
Corey Puffalt
cplists at GMAIL.COM
Fri Feb 25 11:10:16 EST 2005
Yes there's a GD section when viewing phpinfo(); Are you running FC2?
Thanks,
Corey
On Fri, 25 Feb 2005 16:57:41 +0100, Benoît Toutain <bf.toutain at free.fr> wrote:
> Hi Corey,
> perhaps the name of your library file is libgd.so or something like
> that.... or your problem does not come from conflicts between two GD
> libraries. Have you got a GD section when you make a <?php phpinfo(); ?> ?
> Benoît
> Corey Puffalt a écrit :
> >My php.ini doesn't appear to have an extension=gd.so line... nor do
> >any of the files in php.d/* do anyone know how to disable the gd
> >extension with the stock FC2 rpms?
> >Thanks,
> >Corey
> >On Fri, 25 Feb 2005 09:22:59 +0100, Benoît Toutain <bf.toutain at free.fr> wrote:
> >>I commented the extension=gd.so line in my php.ini and restarted apache
> >>and now it works.
> >>No more crash for me too :-)
> >>Thanks a lot
> >>Best regards
> >>Benoît
> >>Constantin Cristian a écrit :
> >>>I got the same problem, I googled for some answers:
> >>>>Use phpinfo() to see if PHP has GD enabled, if it does then either
> >>>>disable the PHP GD extension or make sure that both PHP and MapScript
> >>>>use the same GD version. Also make sure that there is only one copy
> >>>>of libgd.so and of the GD headers on your system.
> >>>So I rebuilt my php installation and this time I used the gd that used to
> >>>build mapscript rather then the bundled php gd
> >>>and surprise... it doesn't crash anymore.
> >>>----- Original Message -----
> >>>From: "c p" <cplists at GMAIL.COM>
> >>>To: <MAPSERVER-USERS at LISTS.UMN.EDU>
> >>>Sent: Thursday, February 24, 2005 7:47 PM
> >>>Subject: Re: [UMN_MAPSERVER-USERS] PHP/Mapscript Crash...
> >>>Benoit,
> >>>Well at least there's someone else to share my pain. :P After doing
> >>>some more reading today I realized I wasn't running php as a cgi but
> >>>as an apache DSO so I thought that must be my problem. Is it still
> >>>true that PHP/Mapscript v4.4.1 still must be run as a cgi? Anyway, I
> >>>reconfigured Apache to call php as a cgi but that did not resolve the
> >>>crash. :(
> >>>Regards,
> >>>Corey
> >>>On Thu, 24 Feb 2005 13:54:54 +0100, Benoît Toutain <bf.toutain at free.fr>
> >>>wrote:
> >>>>Hi Corey,
> >>>>I have the same pb as you.
> >>>>Here is my configuration obtained with <?php
> >>>>dl('php_mapscript.so');phpinfo(); ?>
> >>>>MapServer version 4.2.5 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SWF
> >>>>SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> >>>>SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=EPPL7 INPUT=POSTGIS
> >>>>INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> >>>>($Revision: 1.194.2.6 $ $Date: 2004/08/25 16:27:43 $)
> >>>>Is not there compatibity problems with freetype libraray and another
> >>>>one ?
> >>>>Hope everybody can show us the right way ;-)
> >>>>Best regards,
> >>>>Benoît
> >>>>c p a écrit :
> >>>>>All,
> >>>>>I'm hoping someone here can help or can point me to a more appropriate
> >>>>>forum. I've been having problems getting the samples that ship with
> >>>>>Chameleon v2.0 fully functional. When I attempt to view one of the
> >>>>>sample maps I'm getting a segmentation fault:
> >>>>>==> error_log <==
> >>>>>[Wed Feb 23 15:59:59 2005] [notice] child pid 18222 exit signal
> >>>>>Segmentation fault (11)
> >>>>>By enabling/disabling different layers I was able to narrow the
> >>>>>problem down to the popplace layer and specifically the FONT, TYPE &
> >>>>>SIZE tags (which specify a truetype font) inside the LABEL definition.
> >>>>>Commenting out these three tags result in the layer displaying
> >>>>>(albeit with the default bitmap font). Although I've narrowed what
> >>>>>triggers the crash I still have no idea how to rectify the problem.
> >>>>>I'm further puzzled by the fact that when I use shp2img to render the
> >>>>>map it works fine which seems to suggest the problem is specific to
> >>>>>the php/mapscript module?
> >>>>>I'm running Fedora Core 2 & Mapserver v4.4.1 using the RPMs hosted at
> >>>>>the Mapping Hacks website (http://mappinghacks.com/rpm/). I've
> >>>>>attached the chameleon.map file in case that helps.
> >>>>>Any help would be appreciated.
> >>>>>Thanks,
> >>>>>Corey
