Square polygons appear as triangles
Roberto Bianconi
roberto.bianconi at GMAIL.COM
Fri Feb 25 15:54:59 EST 2005
I have a shp file that describes a grid plot. It is made of adjacent
square polygons and when viewed out of Mapserver it is displayed
correctly.
If I try to plot it with Mapserver, with something like:
LAYER
NAME grd
STATUS DEFAULT
TYPE POLYGON
DATA /path_to_data/grd"
CLASS
EXPRESSION ([VALUE] > 1.e-5 and [VALUE] <= 1.e-4)
COLOR 0 151 255
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION ([VALUE] > 1.e-4 and [VALUE] <= 1.e-3)
COLOR 0 223 255
OUTLINECOLOR 0 0 0
END
END
I get the square polygons represented as triangles, with a line
connecting the lower right corner to the upper left corner (i.e. the
lower left vertex is not connected). If I plot this layer - as a test
- as TYPE POINT and add a CLASS vector symbol and size, I can see the
4 corners of each polygon grid, each with the selected symbol.
Where am I wrong ? Any hint on how to get the correct behaviour?
Thank you.
Roberto
