Itasca 3.5 Demo Error on Mapserver 4.4.1
Ken Lord
kenlord at GMAIL.COM
Mon Feb 28 00:58:34 EST 2005
Hi V, David,
After discussing this problem in a couple messages last week, I
upgraded from mapserver 4.2 to 4.4.1 myself using the windows binary
available on the mapserver homepage.
I ended up stuck with the same problem.
I am no programmer, but Here's what I noticed:
The version from the mapserver homepage is a small .exe that requires
all the separate dll's, the dll versions are different from those of
the previous mapserver versions. MapServer 4.2 would not run using
the new dll's, itself giving the same http header error encountered
when trying to run 4.4.1. ... Are we back to some kind of dll problem?
Regardless, go to www.maptools.org/dl and get their version of
4.4.1. use the mapserv.exe that comes with it and the dll's that are
in the zip files contained within the main zip file you download.
This version is a larger .exe that rellies on fewer dll's ... and on
two separate installations so far IT WORKS!
1st installation: windows 2000
2nd installation: windows xp sp1
Have Fun
Ken Lord
Vancouver BC
On Sun, 27 Feb 2005 23:28:12 -0600, David Radcliffe <rati at post.com> wrote:
> Hi there,
> I'm getting exactly the same problem, only with the latest rendition of
> the demo, source and libraries.
> When I encounter the failure, I can trace it to a call to 'rewind' in the
> function 'int msAddImageSymbol(symbolSetObj *symbolset, char *filename)',
> defined within mapsymbol.c on line 488 (of version 4.4.1 of the source).
> It appears as though the program is failing when it tries to rewind a file
> pointer back to the start of an image file (given a stream). I can't
> explain why this is happening.
> Here's the query string I've been using:
> layer=lakespy2&layer=dlgstln2&zoomsize=2&map=itasca.map&program=mapserv.exe
> &root=.&map_web_imagepath=tmp&map_web_imageurl=tmp&map_web_template=itasca_
> basic.html
> This occurs with the latest binary version AND all versions I have
> compiled myself. I am using Windows XP Professional with SP2 installed.
> Can anyone offer any explanation as to what is happening?
> Thanks,
> David
