Pixmap symbols with Oracle SDO_POINT not showing on the map
Marc Jacquin
marc.jacquin at GEOSYS.COM
Mon Jan 3 06:25:53 EST 2005
Hi Mapserver Users,
First of all : happy new year to everyone.
I am using the DM solution 4.3 windows binaries
MapServer version 4.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=W
MS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
SUPPORTS=WCS_SERVER INPUT=POSTGIS INPUT=ORACLESPATIAL INPUT=OG
R INPUT=GDAL INPUT=SHAPEFILE
I have several layers (polygon and point type) in Oracle 10G SDO. Polygon
layers are displayed correctly. But point layers using PNG pixmap are not
displayed.
The only symptom appears in the MS_ERROR_FILE is Mon Jan 03 10:28:18
2005 - msBuildPath: Unable to access file.
The map file contains Symbol definition like :
SYMBOL
NAME symbolname
TYPE PIXMAP
END
And point layer definition looks like :
LAYER
CONNECTION "something/pass at connection"
CONNECTIONTYPE ORACLESPATIAL
DATA "GEOMETRY FROM (select geometry from jalon where idfarmdata
='2952')"
NAME "JALON"
PROJECTION
"init=epsg:27582"
END
SIZEUNITS PIXELS
STATUS ON
TOLERANCE 3
TOLERANCEUNITS PIXELS
TYPE POINT
UNITS METERS
CLASS
MAXSIZE 100
MINSIZE 1
SIZE 1
SYMBOL symnolname or symbol number (>1) or relative path to the png
file from the map file
END
END
The SQL statement returns a valid geometry : SDO_GEOMETRY(2001, 41014,
SDO_POINT_TYPE(630146.808, 2583979.93, 0), NULL, NULL).
I tried to change the png file path but I still get the same error.
Any idea ?
Marc
