php dso and the mapserv cgi
Ken-ichi
kueda at WSO.WILLIAMS.EDU
Mon Jan 3 12:46:53 EST 2005
Hey, thanks for the reply. Now that I'm back from holiday, I tried
following your advice and recompiling without proj, but I get the same
error. Anyone else have any suggestions?
-Ken-ichi
Thomas Sondag wrote:
> I have the same problem too on a debian Sarge, could you try to build
> (just for test) without the proj4 support ? (not very usable, but seen
> to fix the problem)
> Ken-ichi wrote:
>> Hi all. I tried compiling MapServer against PHP 4.3.10 compiled as an
>> Apache DSO, given recent messages on this list suggesting this was now
>> possible. PHP MapScript seems to work fine, but the mapserv cgi just
>> gives 500 errors, and the error log says "Premature end of script
>> headers: mapserv". I've tried adding lines to httpd.conf specifying the
>> LD_LIBRARY_PATH to all relevant directories, and updating my environment
>> variables (env-update, as I'm on Gentoo), but with no luck. Any idea
>> what's going on? I don't understand why the mapserv cgi even cares how
>> php is running. It's not even using php!
>> Oh, and here are my configure statements, if it helps:
>> APACHE
>> ./configure \
>> --with-openssl \
>> --with-zlib \
>> --with-dbase \
>> --with-dbx \
>> --with-gd=/usr \
>> --with-jpeg-dir=/usr \
>> --with-png-dir=/usr \
>> --with-zlib-dir=/usr \
>> --with-freetype-dir=/usr \
>> --with-mcrypt \
>> --with-pdflib=/usr \
>> --with-pgsql \
>> --with-pspell \
>> --with-pear \
>> --with-apxs2=/usr/local/apache2/bin/apxs \
>> --enable-force-cgi-redirect \
>> --enable-discard-path \
>> --with-regex=system
>> MAPSERVER
>> ./configure
>> --with-gd=/usr \
>> --with-freetype=/usr \
>> --with-zlib=/usr \
>> --with-png=/usr \
>> --with-jpeg=/usr \
>> --with-pdf=/usr \
>> --with-proj=/usr \
>> --with-ogr=/usr/local/bin/gdal-config \
>> --with-gdal=/usr/local/bin/gdal-config \
>> --with-postgis=/usr/local/pgsql/bin/pg_config \
>> --with-wfs \
>> --with-wmsclient \
>> --with-wfsclient \
>> --with-curl-config=/usr/bin/curl-config \
>> --with-httpd=/usr/local/apache2/bin/httpd \
>> --with-php=/usr/local/src/php-4.3.10 \
>> --without-tiff
>> -Ken-ichi
