SDE, WFS and filter encoding
Godwin, Elizabeth
Godwinl at AGR.GC.CA
Wed Jan 5 15:14:23 EST 2005
Thanks!
That's what I was hoping to hear.
Cheers,
Liz
> -----Original Message-----
> From: Yewondwossen Assefa [mailto:assefa at dmsolutions.ca]
> Sent: January 5, 2005 3:13 PM
> To: Godwin, Elizabeth
> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] SDE, WFS and filter encoding
> Hi There,
> I guess there are a couple of issues in this thread and bug
> 1143 : the
> error with GML files and the problems with SDE (they might be related
> hopfully). I will check the GML problem decribed in bug 1143 sometime
> this week (It should be easy to reproduce and test data are
> available).
> We can then look into the SDE problem if the correction for 1143 does
> not apply to SDE layers. I would definitley need help/support on this
> since I do not have SDE here.
> In general if things were working in 4.2.5, It should not
> be too bad
> and should be fixed soon.
> Best Regards,
> Godwin, Elizabeth wrote:
> > HI there,
> > Can a developer please comment on the validity of this bug
> and if it
> > can
> > be fixed? I'm trying to find out if it's a big issue that
> requires a
> > long term workaround or something that could be fixed soon.
> > The issue is that SDE isn't being served well using WFS.
> > Cheers,
> > Liz Godwin
> > *From:* UMN MapServer Users List
> > [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] *On Behalf Of
> *Godwin, Elizabeth
> > *Sent:* December 24, 2004 11:25 AM
> > *To:* MAPSERVER-USERS at LISTS.UMN.EDU
> > *Subject:* [UMN_MAPSERVER-USERS] SDE, WFS and filter encoding
> > Hello list!
> > Has anyone been able to successfully request filtered
> data from a
> > WFS service that connects to SDE?
> > Problem:
> > - Data being served is stored in SDE
> > - Displays ok in all methods (WMS/WFS/direct)
> > - GetFeature returns all features ok
> > - GetFeature with a filter set returns an an error on
> the server:
> > Premature end of script headers: mapserv
> > - sometimes i get a "missing" instead (see bug 1143
> > http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1143)
> > - if I switch the dataset to a shapefile instead, it
> all works just
> > fine.
> > - also have errors with GML in a WMS getFeatureInfo request
> > Cheers, and I hope everyone is enjoying their holidays
> around the
> > world!!
> > Liz Godwin
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax: (613) 565-0925
