adding labels on points after map->draw()
eric BELENFANT
eric.belenfant at AC-ORLEANS-TOURS.FR
Thu Jan 6 11:26:25 EST 2005
Hi !!
I would like to write some lables on points i draw on a map after i calling
map->draw()
I use this piece of code :
# INFOS DE CONNEXION A LA BASE
$dsn = 'mysql://root@amethyse/dep';
$options = array(
'debug' => 2,
'portability' => DB_PORTABILITY_ALL,
$db =& DB::connect($dsn, $options);
# récupération de la liste des communes
$modele = & new carteModel($db);
$modele->calculeCapaciteByCommunes($secteur,$diplome,$filiere,$formation);
$Lcommunes=$map->getLayerByName("communeSelection");
$LSymbolInd=$map->getLayerByName("Indicateurs");
$LSymbolLab=$map->getLayerByName("Indicateurs Labels");
$Lindex=$LSymbolInd->index;
$classe=$LSymbolInd->getClass(0);
$style = $classe->getStyle(0);
#echo $style->size;
$i=0;
$Lcommunes->set("status", MS_ON);
# détermination de l'échelle
# SIZE=1 ====> minimum de capacité
while ($item = $modele->getItem()) {
#echo
$item["code_com"]."".$item["sigle"]."".$cartoSymbol[$item["sigle"]]."<br>";
if ($i==0) $echelle = $item["capa"];
$taille = (int) ($item["capa"]/$echelle) * 10;
$style->set("size",$taille);
#echo "taille ".$item["code_com"]." ".$taille."<br>";
$style->set("offsetx",$taille);
$style->set("offsety",$taille);
# récupération du centre de la commune
#echo $item["code_com"]." toto \n";
if (!$item["code_com"]) continue;
@$Lcommunes->queryByAttributes("CODE_INSEE",$item["code_com"],MS_SINGLE);
if (!$Lcommunes->getNumResults()) continue;
#echo $item["code_com"]." affiché";
$resultat=$Lcommunes->getResult(0);
$Lcommunes->open();
$shape = $Lcommunes->getShape($resultat->tileindex,$resultat->shapeindex);
#$shape = $Lcommunes->getShape(-1,$resultat->shapeindex);
$ShpBounds = $shape->bounds;
$shpMinx = $ShpBounds->minx;
$shpMiny = $ShpBounds->miny;
$shpMaxx = $ShpBounds->maxx;
$shpMaxy = $ShpBounds->maxy;
#print_r($ShpBounds);
$centreX = ($shpMinx + $shpMaxx)/2;
$centreY = ($shpMiny + $shpMaxy)/2;
#print_r($map->extent);
#echo $centreX." / ";
#echo $centreY;
#print_r($shape->bounds);
# écriture des symboles des établissements sur les communes
$point = ms_newPointObj();
#$point->setXY($centreX ,$centreY);
#$point->setXY($centreX + 12 * $i * ($shpMaxx-$shpMinx)/$map->width,$centreY);
$point->setXY($centreX,$centreY);
#echo $classe;
$point->draw($map,$LSymbolInd,$mapImg,0,"");
$point->draw($map,$LSymbolLab,$mapImg,0,"toto");
$i++;
$oldCom=$item["code_com"];
$Lcommunes->close();
$shape->free();
assuming this .map
# COUCHE DYNAMIQUE DES NOMS DE COMMUNES SELECTIONNES AVEC LES LISTES
LAYER
NAME "communeSelection"
GROUP "communes"
TYPE POLYGON
STATUS OFF
CONNECTIONTYPE OGR
CONNECTION "data/communes_eric.TAB"
LABELITEM "NOM_COM"
CLASSITEM "CODE_INSEE"
LABELMINSCALE 150000
#FILTER "1=1"
METADATA
"DESCRIPTION" "|||Communes"
"RESULT_FIELDS" "NOM_COM,PSDC99,SUPERFICIE_KM2,CODE_INSEE"
"RESULT_HEADERS" "|||Nom,Population,Superficie (km2),Indicateurs de
formation"
"RESULT_HYPERLINK" "CODE_INSEE||Voir"
END
CLASS
NAME "Commune analysée"
OUTLINECOLOR 48 106 137
COLOR 255 149 79
TEMPLATE void
#EXPRESSION /45234/
LABEL
COLOR 0 0 127
#BACKGROUNDCOLOR 200 200 100
POSITION AUTO
TYPE bitmap
SIZE tiny
WRAP " "
FORCE TRUE
END
END
END # LAYER
# THEME : affichage des indicateurs (capacité, effectifs ...)
LAYER
NAME "Indicateurs"
GROUP "analyse"
STATUS ON
TYPE POINT
METADATA
"DESCRIPTION" "|||Analyse"
END
CLASS
#NAME "Cercles"
#TEMPLATE void
COLOR 39 152 221
SYMBOL 'circle'
SIZE 3
LABEL
COLOR 0 0 127
POSITION AUTO
TYPE bitmap
SIZE tiny
WRAP " "
FORCE TRUE
END
END
END #LAYER
LAYER
NAME "Indicateurs Labels"
GROUP "analyse"
STATUS ON
TYPE ANNOTATION
METADATA
END
CLASS
LABEL
COLOR 0 0 127
POSITION AUTO
TYPE bitmap
SIZE tiny
WRAP " "
FORCE TRUE
END
END
END #LAYER
but nothing appear when i call the point->draw method ...
I must be wrong somewhere !!!???
eric
