Workshop demo problem
    Ante Drnasin
    ante.dfg at MOJ.NET
    Fri Jan  7 05:04:32 PST 2005
Hi there....we have installed mapserver 4.4.1 on Win2000, apache 1.3.33 and
php 4.3.7(as SAPI)...
The problem started when we wanted to install the workshop demo....
As suggested we changed the hiden vars in index.html so it looks like this
<!-- EDIT THESE HIDDEN VARIABLES -->
      <input type="hidden" name="map"
value="C:/ServerRoot/workshop/itasca.map">
      <input type="hidden" name="program" value="/cgi-bin/mapserv.exe">
      <input type="hidden" name="root" value="C:/ServerRoot/workshop">
      <input type="hidden" name="map_web_imagepath"
value="C:/ServerRoot/workshop/tmp/">
      <input type="hidden" name="map_web_imageurl" value="/workshop/tmp/">
When clicking the initialize button the mapserv.exe crashes with message
"Memory could not be writen" .....in other case the itasca.map file could
not be found....
Here are some other details if needed....
Our server root is in c:/ServerRoot/ ....apache is installed in default
dir.... /cgi-bin/ alias points to  c:/ServerRoot/cgi-bin/ where the
mapserver/bin/ directory is copied to....
If the browser is pointed to mapserver.exe the default message about query
string being empty is displayed....
Any help would be much appricited...if you need any more info just let me
know....
More information about the MapServer-users
