Installation Problem - error while loading shared libraries
Craig Nakamoto
craig.nakamoto at CLAERO.COM
Fri Jan 7 07:32:54 PST 2005
Wim,
Thank you very much for the quick help. This solved my problem right
away!
Craig
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Wim Blanken
Sent: Friday, January 07, 2005 8:17 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Installation Problem - error while
Hello Craig,
Mostly this problem has to do when te applic cannot find the appropriate
library at
rum time. Maybe you forgot to add this.......
add the line:
/usr/local/lib
to the file:
/etc/ld.so.conf
and then run ldconfig (as root):
sudo /sbin/ldconfig
Then try your mapserv executable again.
Regards,
Wim Blanken
The Netherlands
-----Oorspronkelijk bericht-----
Van: UMN MapServer Users List
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Craig Nakamoto
Verzonden: vrijdag 7 januari 2005 15:33
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: [UMN_MAPSERVER-USERS] Installation Problem - error while
Hello,
I am a new user to MapServer and all my test development has occurred on
my local Windows machine. Now I want to create a UNIX MapServer
environment and I am using Red Hat Enterprise v3.
I have reached the point of compiling MapServer itself and I use the
following configure options:
sudo ./configure --with-proj --with-php=/usr/include/php
Everything seems to work fine, and 'configure' locates all the required,
and my requested, optional components (many of which I compiled instead
of using RPMs).
Then I do a 'make' and it looks like it works but when I try to execute
the mapserv binary I get:
[claero at cw2000 mapserver-4.4.1]$ ./mapserv
./mapserv: error while loading shared libraries: libgd.so.2: cannot open
shared object file: No such file or directory
The documentation says that 'something has gone horribly wrong' and to
email this group. Any help would be greatly appreciated.
In the configure output here is the excerpt regarding GD:
configure: checking for GD 2.0.12 or higher...
checking for gdImageSetAntiAliased in -lgd... yes
checking for gdImageSetAntiAliased in -lgd... (cached) yes
using libgd 2.0.12 (or higher) from system libs
(-L/usr/local/lib -lgd -ljpeg -lfreetype -lpng -lz ).
checking for gdImageCreate in -lgd... yes
checking for gdImageGif in -lgd... yes
checking for gdImagePng in -lgd... yes
checking for gdImageJpeg in -lgd... yes
checking for gdImageWBMP in -lgd... yes
checking for gdImageStringFT in -lgd... yes
checking for gdImageGifPtr in -lgd... yes
checking for gdFontGetTiny in -lgd... yes
using GD ( -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP
-DUSE_GD_FT -DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS) from system
libs.
Thanks!
Craig
______________________________________
Craig Nakamoto, Senior Consultant
IT Consulting and Services for Your Business
Claero Systems | www.claero.com
(403) 242-2667 x105 (phone)
(403) 261-0718 (fax)
More information about the MapServer-users
