DBF-to-mySQL JOIN: 3 CASES
Janice Denovan
jdenovan at GEOREFERENCEONLINE.COM
Mon Jan 10 17:35:18 EST 2005
Hi List,
Have enjoyed working with MapServer 4.1 and reading this list over 2 months.
We have a polygon shapefile with 4800 objects (POLY4800.SHP).
We run non-spatial queries against the shape file using an in-house, multi-
user
software application and write the query scores to mySQL 4.x tables.
We extract request_id, object_id and query_score from the mySQL tables
and append to a mySQL table for mapping purposes (tbl_results_mapping.myd).
tbl_results_mapping.myd is indexed on request_id and indexed on object_id).
We need to display the shapefile in MapServ 4.1 symbolized by query_score
and
filtered by request_id. I see this problem as a simple 1:1 table join.
The work is distributed across two servers:
Server1: WinXP/IIS/MapServ 4.1 (supports WMS/WFS)
Server2: WinXP/IIS/mySQL 4.0 (basic mySQL, no spatial extensions)
So far:
### CASE 1
### This mapfile code works but takes 15+ seconds to refresh the map
### Connectiontype OGR
CONNECTIONTYPE OGR
CONNECTION "POLY4800.shp"
DATA "SELECT * FROM POLY4800 LEFT
JOIN 'odbc:hmomap'.tbl_results_mapping ON
POLY4800.OBJECTID = tbl_results_mapping.object_id"
### CASE 2
### This mapfile code executes but fails to apply the WHERE clause
CONNECTIONTYPE OGR
WHERE tbl_results_mapping.request_id = 2"
### CASE 3
### This mapfile code executes and might draw faster for small extents but
### still too slow; WHERE clause not working
### Connectiontype WFS/OGR
CONNECTIONTYPE WFS
CONNECTION "http://127.0.0.1/scripts/mapserv.exe?map=wfs.map"
wfs.map for CASE 3
CONNECTIONTYPE OGR
CLASS
COLOR 255 0 255
END
Can you suggest a way to optimize this system ? A shapefile-based solution
is preferred
at this time.
Thanks very much,
Janice
Vancouver, BC
