Problems with PHP as Module and as cgi with PROJ
Flavio Hendry
flavio at TYDAC.CH
Wed Jan 12 09:05:41 EST 2005
hi william
thanks for your feedback. we solved the problem:
1. going with php as cgi (the issue as module is well know, see
bugzilla 67, thanks danmo).
2. the projection problem was that I was using some old version or that
files where missing. installing the newest one solved it ... (strange
enough it worked as a module, maybe cgi needs more stuff, who knows ...)
in any case we were going nuts yesterday, as bugzilla says "users get
maps from each others requests" and we had that ... kind of fun, you
never know which map will show up next! wow!
the result is on http://waedenswil.mapserver.ch/stadtplan.htm, btw the
first neapoljs 2004 site on-line ...
Mit freundlichem Gruss / Best Regards
Flavio Hendry
TYDAC NEWS http://www.tydac.ch/german/index.php?menu=News_actual
############ Mit freundlichen Gruessen / Kind Regards
############ mailto:flavio at tydac.ch
############ TYDAC AG - http://www.tydac.ch
#### #### Geographic Information Solutions
#### #### Luternauweg 12 -- CH-3006 Bern
############ Tel +41 (0)31 368 0180 - Fax +41 (0)31 368 1860
-----Original Message-----
From: "William Bronsema" <wbronsema at dmsolutions.ca>
To: "'Flavio Hendry'" <flavio at TYDAC.CH>, <MAPSERVER-USERS at LISTS.UMN.EDU>
Date: Wed, 12 Jan 2005 08:11:29 -0500
Subject: RE: [UMN_MAPSERVER-USERS] Problems with PHP as Module and as
cgi with PROJ
> Hi Flavio,
> Just as an FYI - I was at a PHP conference last March and I spoke
> with
> several of the developers in person and they highly recommend to NOT
> use
> Apache 2 especially when running PHP as a module. They indicated
> that they
> focus there attention on making sure that PHP is bullet-proof for
> 1.3.x.
> That is what I understood their position to be concerning Apache 2,
> but that
> might have changed since the release of PHP 5.
> Anyway, I don't know if it's an Apache is the cause here, but it
> might be a
> contributor.
> Regards,
> Bill
> ________________________________________________
> William A. Bronsema, C.E.T.
> Applications and Software Development,
> DM Solutions Group Inc.
> > From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> > Behalf Of Flavio Hendry
> > Sent: January 11, 2005 11:21 AM
> > To: MAPSERVER-USERS at LISTS.UMN.EDU
> > Subject: [UMN_MAPSERVER-USERS] Problems with PHP as Module and as
> cgi with
> > PROJ
> > hi all
> > as follows:
> > - windows 2003
> > - apache 2.0.52
> > - php 4.3.8
> > - ms 4.4 (php_mapscript_44.dll)
> > - dual processor
> > 1. running php as a module:
> > - everything seems to be running fine. as soon as multiple users
> access
> > the application, weard things start to happen: when zooming, all at
> > once the wrong map is delivered (other map as selected or other
> extent)
> > or the application hangs completely, no error in log or whatsoever
> > - apache often crashes with the following message:
> > [notice] Parent: child process exited with status 3221226324 --
> > Restarting.
> > 2. as we suppose that there is a problem running php as a module,
> we
> > try to run it as cgi
> > With the result that the map files are not read at all with the
> > following message (exactly the same map files as with php a module
> > where they run fine, projections are installed in the default
> > dir "c:\proj"):
> > [MapServer Error]: msProcessProjection(): No such file or directory
> > projection used is epsg:9814 or world:CH1903 (both the same):
> > # CH 1903 / Swiss Oblique Cylindrical
> > <9814> +proj=somerc +lat_0=46d57'08.66"N +lon_0=7d26'22.50"E
> > +ellps=bessel +x_0=600000 +y_0=200000
> +towgs84=674.374,15.056,405.346
> > +units=m +k_0=1 +no_defs <>
> > someone has an idea ?
> > thx.
> > Flavio Hendry
