gdal make errors
Paul Smith
paul.oduro at SPPS.ORG
Wed Jan 12 13:37:42 EST 2005
Hello All
I am getting make errors (snippet below) when I run
make
after ./configure --with-ogr --with-xerces=/path/to/xerces
I suspect the error is the '--with-xerces' and also gml.
I am using:
gdal-1.2.5
xerces-2.3.0
on SLES9
gcc-3.3.3-43.24
I know using the newest dist always is setting yourself up but ....
Any help would be greatly appreciated.
paul
ps
Output from make
g++ -Wall -O2 -I../xerces-c-src_2_3_0/include -I../xerces-c-
src_2_3_0/include/x
ercesc -I.. -I../.. -I../../../port -I../../../gcore -I../../../ogr -
I../../../a
lg -I../../../port -DHAVE_XERCES=1 -c gmlfeature.cpp -o ../o/gmlfeature.o
>/dev/
null 2>&1
/bin/sh ../../../libtool --mode=compile g++ -Wall -O2 -I../xerces-c-
src_2_3_
0/include -I../xerces-c-src_2_3_0/include/xercesc -I.. -I../.. -
I../../../port -
I../../../gcore -I../../../ogr -I../../../alg -I../../../port -
DHAVE_XERCES=1 -
c -o ../o/gmlreader.o gmlreader.cpp
src_2_3_0/include/x
I../../../a
lg -I../../../port -DHAVE_XERCES=1 -c gmlreader.cpp -fPIC -DPIC -
o ../o/.libs/g
mlreader.o
In file included from gmlreader.cpp:132:
gmlreaderp.h:64:34: util/PlatformUtils.hpp: No such file or directory
gmlreaderp.h:65:35: sax2/DefaultHandler.hpp: No such file or directory
gmlreaderp.h:66:35: sax2/ContentHandler.hpp: No such file or directory
gmlreaderp.h:67:34: sax2/SAX2XMLReader.hpp: No such file or directory
gmlreaderp.h:68:37: sax2/XMLReaderFactory.hpp: No such file or directory
gmlreaderp.h:77: error: syntax error before `*' token
gmlreaderp.h:78: error: `XMLCh' was not declared in this scope
gmlreaderp.h:78: error: syntax error before `,' token
gmlreaderp.h:79: error: syntax error before `*' token
gmlreaderp.h:80: error: syntax error before `*' token
gmlreaderp.h:81: error: syntax error before `*' token
gmlreaderp.h:90: error: syntax error before `{' token
gmlreaderp.h:99: error: syntax error before `public'
gmlreaderp.h:101: error: destructors must be member functions
gmlreaderp.h:101: error: virtual outside class declaration
gmlreaderp.h:104: error: syntax error before `*' token
gmlreaderp.h:110: error: syntax error before `*' token
gmlreaderp.h:114: error: syntax error before `*' token
gmlreaderp.h:117: error: syntax error before `&' token
gmlreaderp.h:162: error: syntax error before `*' token
gmlreaderp.h:163: error: syntax error before `*' token
gmlreaderp.h:165: error: 'XMLPScanToken' is used as a type, but is not
defined
as a type.
gmlreaderp.h:209: error: syntax error before `&' token
gmlreader.cpp: In constructor `GMLReader::GMLReader()':
gmlreader.cpp:157: error: `m_poGMLHandler' undeclared (first use this
function)
gmlreader.cpp:157: error: (Each undeclared identifier is reported only once
for
each function it appears in.)
gmlreader.cpp:158: error: `m_poSAXReader' undeclared (first use this
function)
gmlreader.cpp: In member function `int GMLReader::SetupParser()':
gmlreader.cpp:205: error: `XMLPlatformUtils' undeclared (first use this
function)
gmlreader.cpp:205: error: syntax error before `::' token
gmlreader.cpp:208: error: syntax error before `&' token
gmlreader.cpp: At global scope:
gmlreader.cpp:219: error: syntax error before `if'
gmlreader.cpp:226: error: ISO C++ forbids declaration of `m_poGMLHandler'
with
no type
gmlreader.cpp:226: error: `int m_poGMLHandler' used prior to declaration
gmlreader.cpp:226: error: syntax error before `(' token
gmlreader.cpp:228: error: syntax error before `->' token
gmlreader.cpp:229: error: syntax error before `->' token
gmlreader.cpp:230: error: syntax error before `->' token
gmlreader.cpp:231: error: syntax error before `->' token
gmlreader.cpp:232: error: syntax error before `->' token
gmlreader.cpp:246: error: syntax error before `->' token
gmlreader.cpp:248: error: syntax error before `->' token
gmlreader.cpp:259: error: ISO C++ forbids declaration of `m_bReadStarted'
with
no type
gmlreader.cpp:262: error: ISO C++ forbids declaration of `PushState' with no
type
gmlreader.cpp:262: error: invalid conversion from `GMLReadState*' to `int'
gmlreader.cpp:264: error: syntax error before `return'
gmlreader.cpp: In member function `void GMLReader::CleanupParser()':
gmlreader.cpp:283: error: type `int' argument given to `delete', expected
pointer
gmlreader.cpp:284: warning: assignment to non-pointer type `int' from NULL
gmlreader.cpp:284: warning: argument to non-pointer type `int' from NULL
gmlreader.cpp: In member function `virtual GMLFeature*
GMLReader::NextFeature()
gmlreader.cpp:305: error: `m_oToFill' undeclared (first use this function)
gmlreader.cpp:317: error: syntax error before `&' token
gmlreader.cpp:338: error: syntax error before `&' token
gmlreader.cpp: In member function `void GMLReader::PushFeature(...)':
gmlreader.cpp:348: error: `pszElement' undeclared (first use this function)
gmlreader.cpp:371: error: `XMLCh' undeclared (first use this function)
gmlreader.cpp:371: error: syntax error before `[' token
gmlreader.cpp:373: error: `anFID' undeclared (first use this function)
gmlreader.cpp:374: error: `attrs' undeclared (first use this function)
make[2]: *** [../o/gmlreader.o] Error 1
make[2]: Leaving directory `/usr/share/gdal-1.2.5/ogr/ogrsf_frmts/gml'
make[1]: *** [gml-target] Error 2
make[1]: Leaving directory `/usr/share/gdal-1.2.5/ogr/ogrsf_frmts'
make: *** [sublibs] Error 2
