gdal make errors
Frank Warmerdam fwarmerdam at GMAIL.COM
Wed Jan 12 19:06:44 PST 2005
On Wed, 12 Jan 2005 16:55:20 -0600, Paul Smith <paul.oduro at spps.org> wrote:
> On Wed, 12 Jan 2005 12:37:42 -0600, Paul Smith <paul.oduro at SPPS.ORG> wrote:
> >Output from make
> >g++ -Wall -O2 -I../xerces-c-src_2_3_0/include -I../xerces-c-
Paul,
The above is your problem.  You can't use a relative
path in the --with-xerces configure.  It has to be
an absolute path.  That is because the path is used
from various submakefiles in other directories.
> I just noticed there is a bug report (for windows however)
> http://208.24.120.44/show_bug.cgi?id=324
> Frank W. do you know if this has been resolved yet? Maybe I will be better
> of using an older version of xerces then.
It has been resolved.  I added a note to bug report.
Best regards,
More information about the MapServer-users mailing list
