TIFF displays and displays not
Jacob Delfos
jacob.delfos at MAUNSELL.COM
Thu Jan 13 01:32:35 EST 2005
Stefan,
this may not be related to the cause, but I have had problems using TIFF from photoshop. Whatever the reason was, it wasn't because it was TIFF instead of geoTIFF, because even with a TFW file, it wouldn't display. It stayed blank. TIFF's not created by photoshop would work fine. There have been other people on the list reporting problems with TIFF from photoshop. I ended up converting to ecw.
Does your php log or webserver log give you any useful errors? Perhaps you could try writing the TIFF from a different program (irfanview?).
regards,
Jacob
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Stefan Schwarzer
Sent: 13 January 2005 14:09
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] TIFF displays and displays not
Ed,
thanks for that.
Still, I can't see the reason for that. I have two TIFF images, which seem to be perfectly similar. I have saved them both from Photoshop. So no GeoTIIFF, only normal TIFF.
How do I get the "mapserv -v" on a Windows machine?
The Linux machine is giving me this:
MapServer version 4.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF
SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Stefan -
The first thing I'd do is run "mapserv -v" on each machine and look for configuration differences in your two MapServer installations. Also, check whether both are GeoTIFFs.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
Sent: Wednesday, January 12, 2005 8:21 AM
Subject: [UMN_MAPSERVER-USERS] TIFF displays and displays not
gush, what a strange thing. I have to TIFFs with a worldfile each. Using PHP/MapScript, on my windows machine, both display nicely. On our Linux machine however, only one of the two displays. When I select the other, white space... Nothing.
I added one of the TIFFs only now, the other already a couple of days ago. Sure, this can't be the reason. But .... Actually, I have no idea. They are both 8 bit, and RGB color mode.
Any idea whatsoever? Thanks for letting me know. I am really stuck...
Stef
_______________________________________
Stefan Schwarzer
GIS & Data Management
UNEP/DEWA/GRID-Geneva
Chemin des Anemones 11
CH - 1219 Chatelaine
Switzerland
Tel: (+41) 22.917.83.49
Fax: (+41) 22.917.80.29
Internet: http://geodata.grid.unep.ch/
Stefan Schwarzer
Switzerland
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050113/d52c7e40/attachment.html
