Crash on querying Oracle Spatial Layers
Francesco Sozzi
fsozzi at INTERCAD.CH
Thu Jan 13 05:54:03 EST 2005
Hi Fernando,
I have troubles on querying Oracle Spatial Layer.
If I use QueryByPoint or QueryByAttribute on an Oracle Layer, Mapserver
crashes generating an application error.
Have you any suggestions?...
I use the following configuartion:
- Mapserver 4.4.1 win32 compiled by me (I did not find a precompiled version
with both Oracle and PHP dll)
- Oracle Enterprise Edition 9
- IIS
- Windows XP
I defined a simple point layer as:
LAYER
NAME "test"
TYPE POINT
CONNECTIONTYPE oraclespatial
CONNECTION "ti_manufatti/avs at franz"
DATA "GEOM FROM (SELECT fid, dist, geom FROM ic_kuba_manufatti) USING
UNIQUE fid"
STATUS DEFAULT
CLASS
NAME "Default"
COLOR 0 0 0
TEMPLATE "templates/default.html"
END
END
And I tried from PHP/Mapscript to do ($pointSubmitted is got in
coordinates):
//get layer
$layer=$gMap->getLayerByName("select");
//query test 1
$qresult = $layer->queryByPoint($pointSubmitted, MS_MULTIPLE, 10);
//query test 2
$qresult = $layer->queryByAttributes("dist", "dist > 0", MS_MULTIPLE);
Best regards
Francesco
