OT: decimal degree conversion
Matt Brown
mbrown at AL1CALL.COM
Thu Jan 13 09:44:07 EST 2005
Joel,
instead of concatenating as strings, you would probably be better off to add
ie,
$longdiv1 = $arrCoords[1] / 60;
$longdiv2 = $arrCoords[2] / 3600;
// create our plotting location
$plot = $long + $longdiv1 + $longdiv2;
Matt
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at lists.umn.edu]On
Behalf Of MapServer User
Sent: Thursday, January 13, 2005 7:47 AM
To: MAPSERVER-USERS at lists.umn.edu
Subject: [UMN_MAPSERVER-USERS] OT: decimal degree conversion
MapServer Users:
I could use some quick help in diagnosing the problem I have with
plotting issues. I use the following PHP to convert a lat/long
(xx:xx:xx) to decimal degrees.
If anyone could point out the flaws, I would appreciate it. Some
plot fine. Others appear to be off. I'm assuming this is the culprit.
Thanks.
// our plotting function to specify degrees
function plot_degrees($location) {
// create an array of our data
$arrCoords = explode(":", $location);
// set our data
$long = $arrCoords[0];
$longdiv1 = round((($arrCoords[1] / 60) * 100));
$longdiv2 = round((($arrCoords[2] / 3600) * 100000));
$plot = $long .= "." . $longdiv1 . $longdiv2;
// return our appended string
return $plot;
MapServer Users:
Thanks.
// set our data
return $plot;
Joel
