Help: MapInfo -> PostGIS -> blank map, projection?
Sam Lawrance
boris at BROOKNET.COM.AU
Thu Jan 13 20:32:50 EST 2005
Daniel Caldeweyher wrote:
>However I can't get it to display anything (blank gif) with Mapserver. I am
>using Apache2 + MapServer 4.4.1(pg) and it appears to be working as I can
>display the "Hello World. Mapserver rocks." example.
>My qldpoa.map file looks like this:
>MAP
> SIZE 400 400
> NAME ABS
> STATUS ON
> #EXTENT 136.440601 -29.177898 153.552171 -9.142186 #from ogrinfo
> EXTENT 98 -45 160 -8 #from MIF
> UNITS dd #kilometers?
> IMAGECOLOR 255 255 255
> IMAGETYPE gif
> LAYER
> NAME "qldpoa_h"
> TYPE POLYGON
> STATUS ON
For starters, you want "STATUS DEFAULT". For layers, "STATUS ON" merely
allows the layer to be turned on through CGI parameters etc; it doesn't
make it "always on".
Sam Lawrance ph +61 0425 228 579 freenode: deft
