Windows 2003 Standard IIS 6.0 trouble
Ed McNierney ed at TOPOZONE.COM
Thu Jan 13 17:43:57 PST 2005
Zach -
IIS doesn't "let the file not be found" - it can't find it.  What is the
URL you are using to refer to your MapServer executable?  Do you have a
virtual directory (if necessary) set up there?  If you use the IIS
administration tool, can you browse to the mapserv.exe file and find it
along the path you expect?
What is the URL you are using that triggers that error?
And please ALWAYS reply to the entire list....
-          Ed
From: Zachary Stauber [mailto:zstauber at bhinc.com]
Sent: Thursday, January 13, 2005 5:09 PM
To: Ed McNierney
Subject: RE: [UMN_MAPSERVER-USERS] Windows 2003 Standard IIS 6.0 trouble
Well, I'm just trying to display the basic Itasca map they offer up on
the Mapserver site http://mapserver.gis.umn.edu/dload.html, I get the
standard message which tells me nothing I can use to find the source of
the problem (the general check engine light of the web server world):
I.                    The page cannot be found
The page you are looking for might have been removed, had its name
changed, or is temporarily unavailable.
Please try the following:
*       Make sure that the Web site address displayed in the address bar
of your browser is spelled and formatted correctly.
*       If you reached this page by clicking a link, contact the Web
site administrator to alert them that the link is incorrectly formatted.
*       Click the Back <javascript:history.back(1)>  button to try
another link.
A.             HTTP Error 404 - File or directory not found.
Internet Information Services (IIS)
Technical Information (for support personnel)
*       Go to Microsoft Product Support Services
<http://go.microsoft.com/fwlink/?linkid=8180>  and perform a title
search for the words HTTP and 404.
*                     Open IIS Help, which is accessible in IIS Manager
(inetmgr), and search for topics titled Web Site Setup, Common
Administrative Tasks, and About Custom Error Messages.
So based on this one would think that the mapserv.exe is in the wrong
place or misspelled, but it's in the exact same place as I have it on a
Windows 2000 install that works fine, and the .map and .html files are
exact copies of those.  So what this error is really telling me is that
IIS 6.0 is not letting the mapserv.exe be found or run.
      -Zack
-----Original Message-----
Sent: Thursday, January 13, 2005 2:56 PM
To: Zachary Stauber; MAPSERVER-USERS at LISTS.UMN.EDU
Zack -
MapServer works just fine under Windows 2003 Standard and IIS 6.0, and
there's plenty of "proof" of that!
But you do need to take the time to understand how your new tools work
rather than blaming them (or MapServer).  You gave us a lot of
information in your email (thanks) but you didn't say what didn't work!
What is the symptom you're seeing?  What are you doing, and what is the
(unexpected) result you're getting?
     - Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
ed at topozone.com
(978) 251-4242
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Zachary L. Stauber
Sent: Thursday, January 13, 2005 4:21 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Windows 2003 Standard IIS 6.0 trouble
Hi, I'm using Windows 2003 Standard, and I'm trying to get MapServ.exe
to work on it.  Right now I'm just trying out the Itasca dataset.  It's
a permissions problem.  Does anyone have a vaguely detailed process for
setting the permissions or configuring Web Access Extensions or
Application Extensions (or whatever hates MapServer so much) so it gets
past the top level security junk in IIS 6.0?
I have the same version, 4.4.0-beta3 working fine on a Windows XP SP2
machine, with all the files in exactly the same places.  The EXE and all
DLL's are in C:\InetPub\scripts\MapServer\ the C:\Proj data has a copy
of everything it's supposed to, and the Itasca data starts in
C:\InetPub\wwwroot\MapServer\NCTCOG\mapserver_demos\workshop
Before you ask, I set all the directories mentioned above to give
WebAdmin all rights (except full control), I changed all the paths to
the correct places in the "index.html" file, which shows the Itasca map
fine under Windows XP SP2, and I added a "MapServer" entry to the Web
Service Extensions and added every EXE and DLL that it uses with
"Allow."  I also set the Web Service Extensions to "Allow" "All Unknown
CGI Extensions" by default (actually that was set when I got here).
I also made the NCTCOG directory in wwwroot a virtual directory and set
"read" permission, set execute permissions to "Script and Executables,"
and created an application extension for ".map" files and set it to the
mapserv.exe executable.  I also did all this for the
C:\InetPub\scripts\Mapserver directory just in case.
What else can I do to loosen this thing up?  Does anyone actually have
it working under Windows 2003 Standard?  I haven't found proof of this
in over a year of back archives on this mailing list.
     -Zack Stauber
      Systems Analyst
      Bohannan-Huston, Inc.
      Albuquerque, NM
      USA
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050113/89b7222a/attachment.htm>
More information about the MapServer-users mailing list
