Windows 2003 Standard IIS 6.0 trouble
    Richard Greenwood
    richard.greenwood at GMAIL.COM
    Thu Jan 13 20:49:26 PST 2005
On Thu, 13 Jan 2005 15:21:24 -0600, Zachary L. Stauber
<zstauber at bhinc.com> wrote:
> Hi, I'm using Windows 2003 Standard, and I'm trying to get MapServ.exe to
> work on it.  Right now I'm just trying out the Itasca dataset.  It's a
> permissions problem.  Does anyone have a vaguely detailed process for
> setting the permissions or configuring Web Access Extensions or Application
> Extensions (or whatever hates MapServer so much) so it gets past the top
> level security junk in IIS 6.0?
> I have the same version, 4.4.0-beta3 working fine on a Windows XP SP2
> machine, with all the files in exactly the same places.  The EXE and all
> DLL's are in C:\InetPub\scripts\MapServer\ the C:\Proj data has a copy of
> everything it's supposed to, and the Itasca data starts in
> C:\InetPub\wwwroot\MapServer\NCTCOG\mapserver_demos\workshop
> Before you ask, I set all the directories mentioned above to give WebAdmin
> all rights (except full control), I changed all the paths to the correct
> places in the "index.html" file, which shows the Itasca map fine under
> Windows XP SP2, and I added a "MapServer" entry to the Web Service
> Extensions and added every EXE and DLL that it uses with "Allow."  I also
> set the Web Service Extensions to "Allow" "All Unknown CGI Extensions" by
> default (actually that was set when I got here).
> I also made the NCTCOG directory in wwwroot a virtual directory and
> set "read" permission, set execute permissions to "Script and Executables,"
> and created an application extension for ".map" files and set it to the
> mapserv.exe executable.  I also did all this for the
> C:\InetPub\scripts\Mapserver directory just in case.
> What else can I do to loosen this thing up?  Does anyone actually have it
> working under Windows 2003 Standard?  I haven't found proof of this in over
> a year of back archives on this mailing list.
>      -Zack Stauber
>       Systems Analyst
>       Bohannan-Huston, Inc.
>       Albuquerque, NM
>       USA
I sent these links to Zach earlier today in response to a direct
email, but I'll include them again for the sake of the achives. It
sounds like you have addressed the issues in this first link:
http://www.microsoft.com/resources/documentation/WindowsServ/2003/standard/proddocs/en-us/Default.asp?url=/resources/documentation/WindowsServ/2003/standard/proddocs/en-us/ca_enabledynamiccontent.asp
This next link may be more relevant in an Active Directory
environment. You grant the IIS_USER_machineName two special rights:
   Adjust memory quotas for a process
and
   Replace a process level token
On a domain this may take a while to propagate.
http://www.microsoft.com/resources/documentation/WindowsServ/2003/standard/proddocs/en-us/Default.asp?url=/resources/documentation/WindowsServ/2003/standard/proddocs/en-us/ca_configcgi.asp
Lastly, use Mozilla, rather than IE as your client. IE will mask some
404 error messages from IIS, which Mozilla will display. These
messages can be invaluable in tracing the root of the error, but I
guess MS thinks they are a security threat or something.
Regards,
Richard Greenwood
richard.greenwood at gmail.com
www.greenwoodmap.com
More information about the MapServer-users
