File wld y extent
Frank Warmerdam
fwarmerdam at GMAIL.COM
Fri Jan 14 13:44:27 EST 2005
On Fri, 14 Jan 2005 12:16:51 -0600, Juan Baron <jbarong at hotmail.com> wrote:
> Hi:
> How is it made the file wld and the values for the parameter extent?
Juan,
Information on the ESRI World file can be found at:
http://geotiff.maptools.org/faq.html#WorldFile1
If you know the top left corner and the pixel size it
is easy to make yourself. As Skweda mentioned you
can also use GeoTiffExaminer, or listgeo to make one
from a GeoTIFF file.
Best regards,
