[UMN_MAPSERVER-USERS] Need Help Displaying Info from DBFs
Skweda O'Bomsawin
sobomsawin at KASSINI.COM
Fri Jan 14 13:56:14 EST 2005
AFAIK, your server will crash with this mapfile... Fisrt, you need a shp
file as DATA, not the dbf (what we call a shapefile is actually made of 3 or
more files: a shp (geographic information), a shx (index info) and a dbf
(tabular information related to the shp)). Mapserver uses the shp to
display geographic information. The dbf is only used to filter this
information or to query the geographic info.
If you only have a dbf file, that means you will need a latitude and a
longitude column in your dbf file to display something...
At this point, you need to check:
- what kind of dbf file you have (alone or with shp and shx)
- If you have a shp and a shx, you just have to replace the DATA and
section of your mapfile and you're done!
- if your dbf is alone, do you have an X and Y or latitude and
longitude column?
- If you have these columns, you will need to create a shapefile
with these coordinates or use the virtual layer function of mapscript...
We are waiting for your input...
Skweda
-----Message d'origine-----
De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] De la
part de Michael Elepano
Envoyé : 14 janvier 2005 13:09
À : MAPSERVER-USERS at LISTS.UMN.EDU
Objet : [UMN_MAPSERVER-USERS] Need Help Displaying Info from DBFs
Hey:
I've been using MapServer for about a month now and have gotten
relatively far with it. But now I've hit a brick wall.
The problem I'm having is showing info from DBFs on my map of the US.
I've got two DBFs (one with all the US counties and one with data-- say
occurences of avalanches-- for each of those county). I'm trying to
color code each county according to occurences of avalanches.
Each DBF has a column called FIPS. The avalanche DBF has a column
called COUNT that is the basis for my colors. I can use EXPRESSION to
single out any column in my county DBF, but I can't seem to reach my
avalanche DBF.
I'm assuming I'll need to do a JOIN. My attempt follows below. Any
advice would be appreciated.
Michael
## my attempt at an avalanche layer
LAYER
NAME "layerAvalanche"
TYPE POLYGON
STATUS ON
DATA "counties.dbf"
PROJECTION
"proj=latlong"
"ellps=GRS80"
"datum=NAD83"
END
CLASS
NAME "classGreen"
OUTLINECOLOR 255 0 255
COLOR 0 255 0
EXPRESSION ([COUNT] > 5)
END
JOIN
NAME "joinAvalanche"
TABLE "C:\my\path\to\avalanches.dbf"
FROM "FIPS"
TO "FIPS"
END
END
No virus found in this incoming message.
Checked by AVG Anti-Virus.
Version: 7.0.300 / Virus Database: 265.6.11 - Release Date: 2005-01-12
No virus found in this outgoing message.
