QueryByRect Problems on shp point
Francesco Sozzi
fsozzi at INTERCAD.CH
Mon Jan 17 05:55:02 EST 2005
Hi all,
I am having problems on querying a shapfile layer of type point.
The code I use is:
$qresult = $layer->queryByRect($rectDrawnedMapCoord);
where $rectDrawnedMapCoord is a rectangle with map coordinates that contains
several points.
The problem is that I get an empty result.
Here you are some notes:
- I have problems only on shapefile layers of type point; queryByRect works
properly on shapefile polygon and line
- I an Oracle Spatial copy (exatly the same point objects and data) an it
works: I get right resul on queryByRect
Anybody have any suggestions?
Best regards
Francesco
PS: Here you are an extract of mapfile:
# ic_manufatti (ORACLE LAYER: IT WORKS!!)
LAYER
NAME "ic_manufatti"
TYPE POINT
CONNECTIONTYPE oraclespatial
CONNECTION "ti_manufatti/avs at franz"
DATA "GEOM FROM (SELECT fid, dist, geom FROM ic_kuba_manufatti WHERE geom
IS NOT NULL) USING UNIQUE fid"
STATUS OFF
METADATA
ic.layer.key "FID"
ic.layer.key.type "numeric"
ic.form.key "FID"
END
CLASS
NAME "Default"
COLOR 0 0 0
SYMBOL "circle"
SIZE 10
TEMPLATE "templates/default.html"
END
END
# ic_manufattishp (SHAPEFILE LAYER: IT DOES NOT WORK!!)
LAYER
NAME "ic_manufattishp"
TYPE POINT
DATA "manufattishp"
STATUS DEFAULT
METADATA
ic.layer.key "NUMERO"
ic.layer.key.type "string"
ic.form.key "NUMERO"
END
CLASS
NAME "Default"
COLOR 125 0 0
SYMBOL "circle"
SIZE 10
END
END
