RES: [UMN_MAPSERVER-USERS] Closed Polygon
Murilo Lacerda Yoshida
murilo.yoshida at AGX.COM.BR
Tue Jan 18 06:08:58 EST 2005
Hi all,
I have a doubt about polygons...
Let me explain.. In my application, I have to divide a area into
several squares. Sometimes some squares have a bizarre shape.
It sis happen this time. A have a square that is actually 2 polygons,
one in the top left and the other on the low right.
There is a way to create a polygon that represents this?
Thanks,
Murilo
-----Mensagem original-----
De: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] Em
nome de Ed McNierney
Enviada em: segunda-feira, 17 de janeiro de 2005 23:31
Para: MAPSERVER-USERS at LISTS.UMN.EDU
Assunto: Re: [UMN_MAPSERVER-USERS] Closed Polygon
Ken -
Yes, that defines what a polygon means - in an ESRI shapefile.
Rick, the problem is not "defining" a closed polygon so much as
"specifying" one. "Closed" is a little redundant here, since a polygon
has to be closed in the sense I think you're using it. If it's not
closed, it's a polyline.
I think your question is more a matter of agreement over the XML schema
used and its interpretation.
- Ed
Ed McNierney
TopoZone.com
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Ken Lord
Sent: Monday, January 17, 2005 6:04 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Closed Polygon
I knew that BCIT course was good for something ..
bango! ...
http://www.esri.com/library/whitepapers/pdfs/shapefile.pdf
Page 12 defines what a polygon is according to the ESRI Shapefile
format.
"A polygon consists of one or more rings. A ring is a connected
sequence of four or more points that form a closed,
non-self-intersecting loop."
Think of it this way, the simplest polygon is a triangle, but it takes
the four points to describe a polygon in a shapefile, therefore the
start and end point must be the same.
Page 13 lists some important points about polygons, one of which
explicitly states that the start and end points must be the same.
Cheers,
Ken Lord
Vancouver BC
On Mon, 17 Jan 2005 15:09:06 -0500, Rick Levine
<Richard_D_Levine at raytheon.com> wrote:
> Can anyone point me to a URL that defines a close polygon as one in
which
> the last point equals the first?
> I'm in the middle of a raging debate (tempest in a teapot) of what a
closed
> polygon is. I'm getting polygons in XML from other systems where the
XML
> schema defines polygons as closed. Some of the other systems disagree
> about what this means.
> BTW: I Googled and looked at opengis.org, but it seems no one bothers
to
> define something so obvious.
> Thanks, and sorry for being a little off topic.
> Rick
> CONFIDENTIALITY: This email contains no useful information. Ignore
it.
