Querying a layer in Perl
Lowell Filak
lfilak at MEDINACO.ORG
Tue Jan 18 08:27:29 EST 2005
I think a template is required on the layer.
$lyr->{template} = "bogus.html";
HTH
Lowell
The following message was sent by Aaron Craig <mercutio at POBOX.COM> on
Tue, 18 Jan 2005 12:31:25 +0100.
> I had some code working that performed a query on a layer in a recent
> pre 4.4 version of mapserver.
> I've dusted it off and stuck it into a project I'm working on, and lo
> and behold, it doesn't work!
> I'm sure I'm missing something simple, but can't find it.
> Any input is appreciated.
> Here's a script that demonstrates the problem. The coordinates of the
> point I'm querying must work, as I've lifted them directly from my
> Postgis database. I open() the layer and set its status to ON, though
> I'm not sure that is necessary. I've also played with the buffer
> parameter, but since I'm sending exactly the right point in, I don't
> think that should make any difference. I've also played with the type
> parameter, but both MS_SINGLE and MS_MULTIPLE result in no results.
> Here's the script:
> #!/usr/bin/perl
> use warnings;
> use strict;
> use mapscript;
> $| = 1;
> my $map = new mapscript::mapObj("test.map");
> my $lyr = $map->getLayerByName("museum");
> $lyr->open();
> $lyr->{status} = $mapscript::MS_ON;
> my $pnt = mapscript::pointObj->new();
> $pnt->{x} = 1536958.9653;
> $pnt->{y} = 4439455.78984656;
> my $rst = $lyr->queryByPoint($map, $pnt, $mapscript::MS_MULTIPLE, 0);
> if($rst == $mapscript::MS_FAILURE)
> my $err = mapscript::errorObj->new();
> if($err->{code} != 18)
> print "Error running query on layer.";
> exit;
> print "got ".$lyr->getNumResults()." results (expecting 1)\n";
> The relevant layer declaration in the mapfile:
> LAYER
> NAME "museum"
> TYPE POINT
> STATUS OFF
> CONNECTION 'user=postgres dbname=postgis_sardegna'
> CONNECTIONTYPE POSTGIS
> DATA 'point_geom from museum'
> CLASS
> NAME 'Museums'
> STYLE
> SYMBOL "/var/www/mapserver/htdocs/imgs/museum_icon.png"
> END
> END
> END
> And here's the result of a select query on my database:
> select * from museum;
> id | name | xdb_id | point_geom
> 1 | museum 1 | | SRID=-1;POINT(1536958.9653 4439455.78984656)
> (1 row)
> Aaron Craig
> mercutio at pobox.com
> Get Firefox!
> http://www.spreadfirefox.com/?q=affiliates&id=0&t=1
