Labels in two renderings of the same map ?
    Lowell Filak
    lfilak at MEDINACO.ORG
    Tue Jan 18 08:56:19 PST 2005
It sounds like the label cache is empty by the time the second image is
rendered.
Have you tried to render the second image from a second map object?
Lowell
The following message was sent by "Lars V. Nielsen (GisPro)"
<LVN at GISPRO.DK> on Sun, 16 Jan 2005 13:12:20 +0100.
> I've been asked to generate a map with an insert, i.e. adding a small
area with a larger scale in the corner of the map.
> I've accomplished it by performing two renderings of the same map, the
second rendering after setting a smaller width/height and a
> fixed extent, and using GD2 to merge the two images appropriately.
This works perfectly.
> However, I've sofar been unable to get labels to display in the small
insert image. They show up perfectly in the main/large image.
> I don't turn any layers on/off between the two renderings, and I don't
have any label min/max scale settings in place for this
> labelling layer (which btw. is an OVF layer).
> I suspect that it's an issue connected with the label cache. I've
tried to add LABELCACHE OFF to the labelling layer and remove the
> commands $map->drawLabelCache() from my code, but it makes no
difference at all: the labels only (and always!) appear in the main
> window.
> If anyone has come up with a way to control labels in two map
renderings, I'll be delighted to know.
> Best regards/Med venlig hilsen
> Lars V. Nielsen
> GisPro, Denmark
> http://www.gispro.dk/
More information about the MapServer-users
