time queries with mapserver 4.4.1
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Wed Jan 19 07:42:07 PST 2005
There is a doc explaining the current wms time support in Mapserver at :
http://mapserver.gis.umn.edu/doc/wms-time-support-howto.html
Later,
Trond Michelsen wrote:
> Hi.
> I'm still unsuccessful in trying to understand how to make a time
> query in mapserver 4.4.1, and I'd appreciate any help on the subject.
> I have several layers that I access with WMS through mapserver, and
> some of these layers can show data for different dates and times.
> Here's an example of a layer definition in my map file.
> --8<--
> LAYER
> NAME "wind"
> STATUS ON
> TYPE RASTER
> OFFSITE 255 255 255
> CONNECTION "http://wmsserver/cgi-bin/wms.cgi?"
> CONNECTIONTYPE WMS
> PROJECTION
> "proj=stere"
> "a=6371000"
> "b=6371000"
> "lat_0=90"
> "lat_ts=60"
> "lon_0=0"
> END
> METADATA
> "wms_name" "wind"
> "wms_server_version" "1.1.1"
> "wms_formatlist" "image/png"
> "wms_format" "image/png"
> END
> END
> --8<--
> I've seen suggestions that it's possible to use %var% for every
> parameter in the query string, so I tried to add "wms_time %time%" to
> the metadata, and then add a select-box with appropriate dates to the
> web-page, but that passed "time=%25time%25" to the WMS-server.
> Being able to make queries at all is of course the most important
> issue I'd like to have solved, but I'm also a bit curious about how I
> define which times that are appropriate. How do I configure the
> mapfile, so that mapserv.cgi adds the proper <dimension>-tag to a
> GetCapabilities response? Also, is it possible to get mapserv.cgi to
> automatically fill inn available dates in the web template, or will I
> have to change it every time the available dates changes?
> Trond Michelsen
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
More information about the MapServer-users
