Need Help Displaying Info from DBFs
Michael Elepano
michael at LIVEPROCESS.COM
Wed Jan 19 12:31:55 EST 2005
Holger:
This sounds like it will do exactly what I need. I'm in PHP. I have
one shp/shx set but multiple dbfs to map onto it. Please post so we
can all enjoy.
Michael
On Jan 19, 2005, at 2:24 AM, Holger Floerke wrote:
> I am working on a solution where you can specify the dbf-filename
> seperate
> from the shapefile-filename with php mapscript. The main advantage is
> you
> don't have to waste space for the copies of the shp/shx-files. You
> have to
> use php, but you can join/switch your dbf-files easily. If somebody is
> interested in, I will post the code modifications to the list.
> HolgeR
