QueryByRect Problems on shp point
Francesco Sozzi
fsozzi at INTERCAD.CH
Wed Jan 19 13:05:56 EST 2005
Hi Lowell,
no, I think coordinates are correct.
I create rectangle by:
$newExtentScreenCoordStr = explode(" ",$hiddenMapImageBox);
$newExtentScreenCoord = ms_newrectObj();
$newExtentScreenCoord->setextent($newExtentScreenCoordStr[0],
$newExtentScreenCoordStr[1],
$newExtentScreenCoordStr[2],
$newExtentScreenCoordStr[3]);
Where $hiddenMapImageBox is a box created by jBox.
Please also note that the same rectangle works properly for lines and
polygons and that it works properly for point on Oracle.
Best regards
Francesco
----- Original Message -----
To: "Francesco Sozzi" <fsozzi at intercad.ch>; "Lowell Filak"
<lfilak at MEDINACO.ORG>; <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Wednesday, January 19, 2005 2:29 PM
Subject: Re: [UMN_MAPSERVER-USERS] QueryByRect Problems on shp point
> Strange.
> Is there any chance the points don't form a rectangle but rather a
> parallelogram, quadrilateral, ...?
> What if you draw the shapeobj on the map?
> Lowell
> The following message was sent by "Francesco Sozzi" <fsozzi at intercad.ch>
> on Wed, 19 Jan 2005 10:07:52 +0100.
> > Hi Lowell,
> > No I haven't any logging.
> > At the moment I solved the problem by converting rectangle into a shape
> > object and issuing a QueryByShape: in this way it works.
> > Strange...
> > Francesco
> > From: "Lowell Filak" <lfilak at MEDINACO.ORG>
> > To: <MAPSERVER-USERS at LISTS.UMN.EDU>
> > Sent: Tuesday, January 18, 2005 6:13 PM
> > > The following message was sent by Francesco Sozzi <fsozzi at INTERCAD.CH>
> > > on Mon, 17 Jan 2005 11:55:02 +0100.
> > > > Hi all,
> > > > I am having problems on querying a shapfile layer of type point.
> > > > The code I use is:
> > > > $qresult = $layer->queryByRect($rectDrawnedMapCoord);
> > > > where $rectDrawnedMapCoord is a rectangle with map coordinates that
> > > contains
> > > > several points.
> > > > The problem is that I get an empty result.
> > > > Here you are some notes:
> > > > - I have problems only on shapefile layers of type point;
queryByRect
> > > works
> > > > properly on shapefile polygon and line
> > > > - I an Oracle Spatial copy (exatly the same point objects and data)
an
> > it
> > > > works: I get right resul on queryByRect
> > > > Anybody have any suggestions?
> > > Francesco,
> > > Do you have any logging turned on that could point to a problem
possibly
> > > accessing the shapefile?
> > > Lowell
