WMS error after upgrade to 4.4
Tracy Howlett
Tracy at CHIRPWHISTLER.INFO
Wed Jan 19 21:00:18 EST 2005
I am getting the same error message as before.
Is there something about the actual data that has to be OGC compliant?
Absolutely nothing changed between the upgrade so I'm a little stumped here!
Tracy Howlett
Community Habitat Resources Project
GIS Web Development Coordinator
PO Box 1122, Whistler, BC, V0N 1B8
Phone: 604 932 2019
Fax: 604 932 2077
Web: www.CHiRPwhistler.info
Forum: www.CHiRPwhistler.info/forums/index.php
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Yewondwossen Assefa
Sent: Wednesday, January 19, 2005 5:38 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] WMS error after upgrade to 4.4
In the GetMap request the LAYERS parameter is required (unless there is
an SLD parameter defined) in wms 1.1.1. So you should add that to all
your request. In your case, if you want all the layers to be returned
you could use the map name as the layers parameter :
http://www.chirpwhistler.info/scripts/mapserv.exe?map=chirp_wms.map&VERSION=
1.1.1&SERVICE=wms&REQUEST=GetMap&LAYERS=CHIRP_WMS
Tracy Howlett wrote:
> Here is my getmap request:
> And here is the sample of my cascading mapfile and the base mapfile
> I really appreciate your help!
> Cascade (c:\inetpub\scripts\chirp_wms.map):
> # Start of map file
> # Sample map file for a chameleon app.
> NAME CHIRP_WMS
> STATUS ON
> SIZE 570 360
> SYMBOLSET "c:\chameleon-2.0\CHiRP\etc\symbols.sym"
> EXTENT 486515 5541282 512169 5559285
> UNITS METERS
> SHAPEPATH "c:\chameleon-2.0\CHiRP\data\"
> IMAGECOLOR 255 255 255
> FONTSET "c:\chameleon-2.0\CHiRP\etc\fonts.txt"
> # Start of web interface definition
> WEB
> # On Windows systems, /tmp and /tmp/ms_tmp/ should be created at the root
> # of the drive where the .MAP file resides.
> IMAGEPATH "/tmp/ms_tmp/"
> IMAGEURL "/tmp/"
> METADATA
> "wms_title" "CHIRP_WMS"
> "wms_onlineresource"
"http://www.chirpwhistler.info/scripts/mapserv.exe?map=c:\chameleon-2.0\CHiR
> P\map\chirp.map&"
> END
> END
> PROJECTION
> "init=epsg:26910"
> END
> # Start of layer definitions
> LAYER
> NAME "RMOW Boundary"
> TYPE RASTER
> STATUS ON
> CONNECTION
"http://localhost/scripts/mapserv.exe?map=c:\c:\chameleon-2.0\chirp\map\chir
> p.map&"
> CONNECTIONTYPE WMS
> METADATA
> "wms_title" "RMOW"
> "wms_srs" "EPSG:42304 EPSG:42101 EPSG:4269 EPSG:4326
> EPSG:42304 EPSG:26910"
> "wms_name" "RMOW "
> "wms_server_version" "1.11"
> "wms_formatlist" "image/gif,image/png,image/jpeg,image/wbmp"
> "wms_format" "image/gif"
> END
> END
> LAYER
> NAME "Municipal Park"
> TYPE RASTER
> STATUS ON
> CONNECTION
"http://www.chirpwhistler.info/scripts/mapserv.exe?map=c:\chameleon-2.0\chir
> p\map\chirp.map&"
> CONNECTIONTYPE WMS
> METADATA
> "wms_title" "Park"
> "wms_name" "Park"
> "wms_server_version" "1.1.1"
> END
> LAYER
> NAME "Buildings"
> TYPE RASTER
> STATUS ON
> CONNECTION
> P\map\chirp.map&"
> CONNECTIONTYPE WMS
> METADATA
> "wms_title" "Buildings"
> "wms_srs" "EPSG:26910"
> "wms_name" "Buildings"
> END
> END
> Base MapFile (c:\chameleon-2.0\chirp\map\chirp.map):
> # Start of map file
> NAME CHiRP
> STATUS ON
> SIZE 570 360
> SYMBOLSET "../etc/symbols.sym"
> UNITS METERS
> SHAPEPATH "../data/"
> FONTSET "../etc/fonts.txt"
> WEB
> MINSCALE 1300
> MAXSCALE 13000000000
> IMAGEURL "/tmp/"
> # LOG "/tmp/gmap.log"
> METADATA
> "wms_title" "CHiRP"
"http://www.CHiRPwhistler.info/scripts/mapserv.exe?map=c:\chameleon-2.0\CHiR
> P\map\chirp.map&"
> END
> END
> # Start of reference map
> REFERENCE
> IMAGE images/whistler_sm.png
> STATUS ON
> COLOR -1 -1 -1
> OUTLINECOLOR 255 0 0
> SIZE 75 50
> END
> # Start of legend
> LEGEND
> STATUS ON
> KEYSIZE 18 12
> # LABEL object
> LABEL
> TYPE BITMAP
> SIZE MEDIUM
> COLOR 0 0 89
> END
> TEMPLATE "legend3.html"
> END
> # Start of scalebar
> SCALEBAR
> LABEL
> COLOR 0 0 0
> SIZE SMALL
> END
> SIZE 150 5
> COLOR 255 255 255
> BACKGROUNDCOLOR 0 0 0
> OUTLINECOLOR 0 0 0
> UNITS Kilometers
> INTERVALS 5
> STATUS ON
> END
> QUERYMAP
> STATUS ON
> STYLE HILITE
> COLOR 255 0 0
> END
> PROJECTION
> "init=epsg:26910"
> END
> # MUNICIPAL PARK
> LAYER
> GROUP "Recreation"
> TYPE POLYGON
> DUMP TRUE
> TEMPLATE "blank.html"
> TOLERANCE 10
> TOLERANCEUNITS PIXELS
> STATUS ON
> DATA "Park"
> PROJECTION
> "init=epsg:26910"
> END
> CLASS
> COLOR 150 231 138
> END
> METADATA
> WMS_GROUP_TITLE "Recreation"
> WMS_TITLE "Park"
> WMS_ABSTRACT "Park"
> WMS_SRS "EPSG:26910"
> END
> END
> # RMOW BOUNDARY
> LAYER
> NAME "Resort Municipality of Whistler"
> TYPE LINE
> STATUS ON
> GROUP "Boundaries"
> DATA "RMOW"
> PROJECTION
> "init=epsg:26910"
> END
> CLASS
> COLOR 168 0 0
> SYMBOL "Line"
> SIZE 2
> END
> METADATA
> WMS_GROUP_TITLE "Boundaries"
> WMS_TITLE "RMOW"
> WMS_ABSTRACT "Resort Municipality of Whistler Boundary"
> END
> END
> # BUILDINGS
> LAYER
> NAME "Buildings"
> GROUP "Civic Information"
> TYPE POLYGON
> DATA "Building"
> MAXSCALE 15000
> STATUS ON
> TOLERANCE 10
> CLASSITEM "Class"
> PROJECTION
> "init=epsg:26910"
> END
> CLASS
> NAME "Accomodation"
> EXPRESSION "Accomodation"
> OUTLINECOLOR 0 0 0
> COLOR 230 0 0
> END
> CLASS
> NAME "Commercial"
> EXPRESSION "Commercial"
> OUTLINECOLOR 0 0 0
> COLOR 0 77 168
> END
> CLASS
> NAME "Residential"
> EXPRESSION "Residential"
> OUTLINECOLOR 0 0 0
> COLOR 200 133 68
> END
> CLASS
> NAME "Lift Base"
> EXPRESSION "Lift Base"
> OUTLINECOLOR 0 0 0
> COLOR 0 0 0
> END
> CLASS
> NAME "Municipal"
> EXPRESSION "Municipal"
> OUTLINECOLOR 0 0 0
> COLOR 130 155 90
> END
> CLASS
> NAME "Other"
> OUTLINECOLOR 0 0 0
> EXPRESSION ""
> COLOR 130 130 130
> END
> CLASS
> NAME "Commercial"
> COLOR 0 77 168
> END
> METADATA
> WMS_GROUP_TITLE "CivicInformation"
> WMS_TITLE "Buildings"
> WMS_ABSTRACT "Buildings"
> END
> END
> Tracy Howlett
> Phone: 604 932 2019
> Fax: 604 932 2077
> From: Yewondwossen Assefa [mailto:assefa at dmsolutions.ca]
> Sent: Wednesday, January 19, 2005 5:18 PM
> To: Tracy Howlett
> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> Do you have an example of a getmap URL returing the exception and maybe
> your map definition ?
> There has been some work done in the wms code before the 4.4 release so
> that mapserver would be OGC compliant (so more parameter tesing and
> exception generating has been added) and this may explain the problems
> your are having.
> Later,
>>Hello,
>>I've recently upgraded to MapServer 4.4 after running 4.0.1 successfully
>>for over a year. I have been using a Cascading WMS service to share
>>some of my layers out to another MapServer user who has been accessing
>>my data without problem.
>>For some reason, now that MapServer 4.4 is running, the WMS layers are
>>no longer being shared. We have run the getCapabilities for both my
>>base mapfile and my cascaded map file service and they both come back
>>error free but when we run a getMap we receive the following error:
>><?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?> <!DOCTYPE
>>ServiceExceptionReport SYSTEM
>>"http://schemas.opengeospatial.net/wms/1.1.1/exception_1_1_1.dtd">
>><ServiceExceptionReport version="1.1.1"> <ServiceException
>>code="LayerNotDefined">
>>msWMSLoadGetMapParams(): WMS server error. Invalid layer(s) given in the
>>LAYERS parameter.
>></ServiceException>
>></ServiceExceptionReport>
>>I've read about this error in the archives but cannot find a solution
>>for my particular file. When my colleague calls the mapfile only one of
>>the 10 layers listed is returned.
>>The data has not changed since I upgraded and it is all in the same
>>projection (UTM Zone 10). Are there some naming conventions or WMS
>>requirements that are new in 4.4 that I have not found in the
> documentation?
>>Any help would be greatly appreciated as we are trying to get this thing
>>up and running again for a presentation on Saturday.
>>Thanks,
>>**Tracy Howlett**
>>Phone: 604 932 2019
>>Fax: 604 932 2077
>>Web: www.CHiRPwhistler.info <http://www.CHiRPwhistler.info>
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
