Case of the blankety blanks
Chris Foote
chris at INETD.COM.AU
Thu Jan 20 03:40:09 EST 2005
I've managed to get CGIMapServer up and running, and I'm able to
embed a label and scale. The problem I'm having is getting either
one of 2 shapefiles to be displayed - they come up blank ;-(
What I'm seeing, along with the shapefiles and debugging info is
up at:
http://202.4.251.202/cgi-bin/mapserv?map=maps%2FAustralia2.map&imgext=-4052773.126174+6525496.338892+-4048707.504070+6529560.938500&imgxy=149.5+199.5&program=%2Fcgi-bin%2Fmapserv&img.x=335&img.y=321
or:
http://tinyurl.com/5c3x5
I'm trying to show 4 layers:
- a label (working)
- a scale (working)
- Australia2 shapefile (not working)
- Trenches shapefile (not working)
I suspect that I don't know enough about the types of projections.
Can anyone help ?
The shapefile Australia2 is supposed to be a Asia Lambert Conformal
Conic projection. The shapfile Trenches is supposed to be a GDA
1994 South Australia Lambert projection.
The map file contains:
MAP
NAME MapTest
STATUS on
DEBUG on
IMAGETYPE myoutputformat
SIZE 500 500
UNITS METERS
EXTENT -1212976 561048 2859174 4723198
SHAPEPATH "/home/pipe/shapes/"
PROJECTION
"proj=lcc"
END
LEGEND
STATUS EMBED
POSITION UR
END
SCALEBAR
TRANSPARENT ON
BACKGROUNDCOLOR 254 254 254
STATUS EMBED
POSITION LR
STYLE 1
UNITS meters
LABEL
SIZE small
END
END
LAYER
NAME Australia2
DATA Australia2
TYPE polygon
STATUS on
DEBUG on
PROJECTION
"proj=lcc"
END
CLASS
BACKGROUNDCOLOR 100 100 100
DEBUG on
OUTLINECOLOR 150 150 150
END
END
LAYER
NAME Trenches
DATA Trenches
TYPE polygon
STATUS on
DEBUG on
CLASS
DEBUG on
END
END
LAYER
NAME "credits"
STATUS DEFAULT
TRANSFORM FALSE
TYPE ANNOTATION
FEATURE
POINTS
10 480
END
TEXT 'Bogus Mapping Limited'
END
CLASS
LABEL
TYPE BITMAP
POSITION CR
COLOR 0 0 0
END
END
END
OUTPUTFORMAT
NAME myoutputformat
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB
EXTENSION "png"
END
WEB
IMAGEPATH ../data/
LOG ../data/logfile.txt
TEMPLATE "Australia2.html"
IMAGEURL "/mapdata/"
END
END
Any help would be most appreciated ;-)
Cheers,
Chris Foote <chris at inetd.com.au>
_ _ _ Jabber: chris at jabber.inetd.com.au
(_) | | | | Director - INETD PTY LTD
_ _ __ ___ | |_ __| | Level 2, 132 Franklin St
| | | '_ \ / _ \ | __| / _` | Adelaide SA 5000
| | | | | | | __/ | |_ | (_| | Web: http://www.inetd.com.au
|_| |_| |_| \___| \__| \__,_| Phone: (08) 8410 4566
