access to KEYIMAGE from Class object in mapscript
Bel Sébastien
s-bel at VILLE-THONON.FR
Tue Jan 25 12:01:05 EST 2005
> I've tried to use it as following :
> -> mapfile :
> LAYER # RASTER 2
> GROUP IGN
> NAME 'Nord-ouest'
> DATA IgnScan25/G092_052.tif
> STATUS DEFAULT
> TYPE RASTER
> PROJECTION
> "init=epsg-dist:27572"
> END
> CLASS
> NAME 'Nord-ouest'
> KEYIMAGE 'ignG.gif'
> END
> END # END RASTER 2
> -> code :
> $classes = $currentLayer->getClasses();
> foreach ($classes as $class) {
> $layImgUrl = $class->keyimage;
> error_log('main.phtml > icon get from keyimage = '.$layImgUrl,0);
> $class->keyimage return always a null string in spite of KEYIMAGE keyword in the class section...
> Perhaps $classObj->keyimage doesn't implemented ?
> Does somebody know the answer ?
> Thanks.
> Sebastien
> -----Message d'origine-----
> De: Lowell Filak [SMTP:lfilak at medinaco.org]
> Date: vendredi 14 janvier 2005 17:07
> À: Bel Sébastien; MAPSERVER-USERS at LISTS.UMN.EDU
> Objet: Re: [UMN_MAPSERVER-USERS] access to KEYIMAGE from Class object in mapscript
> I believe "keyimage" should be a member of classobj.?
> Lowell
> The following message was sent by =?iso-8859-1?Q?Bel_S=E9bastien?=
> <s-bel at VILLE-THONON.FR> on Fri, 14 Jan 2005 11:23:27 +0100.
> > Hi list,
> > i'd like to retreive the keyimage value of a class from my mapfile
> using > php.
> > i've not found any attributs or method into the Class object of >
> phpmapscript
> > to do that.
> > how is it possible ?
> > Thank's for your help.
> > Sébastien
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050125/df813851/attachment.html
