Zoom to custom extent - PHP
Matt Brown
mbrown at AL1CALL.COM
Tue Jan 25 14:25:58 EST 2005
Kevin,
you need to either separate your extents with a comma in the form, or change
the first option in the explode function to look for a ' ' instead of ','
Matt
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
Behalf Of Kevin Grootendorst
Sent: Tuesday, January 25, 2005 1:11 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Zoom to custom extent - PHP
Bill,
Thanks for the direction. I'm still a little stuck. Just to clarify, I
have the following code:
In my app_contents.php file:
<SELECT NAME="ViewRegion">
<OPTION VALUE="7120999 827999 7599999 1119999">Lake Ontario</OPTION>
<OPTION VALUE="7200000 833270 7291840 894520">Niagara (ON)</OPTION>
<OPTION VALUE="7150000 878000 7210000 880000">Hamilton-Wentworth</OPTION>
</SELECT >
In my app.php file:
(the code that you provided)
// check if quick zoom is requested
if ( isset( $http_form_vars['ViewRegion'] ) && strlen($http_form_vars
['ViewRegion'] ) > 0 )
// separate values
$adExtents = explode( ',', $http_form_vars['ViewRegion'] );
// set extent
$oMapSession->oMap->setExtent( $adExtents[0], $adExtents[1],$adExtents
[2], $adExtents[3] );
This isn't quite working yet, but is this really all the code I'll need?
Should my drop-down box be set as a form?
Thanks again for your help - this has been very frustrating.
Kevin
