php-mapscript tile indexing
Kristjan Annus kristjan at TARKVARASTUUDIO.EE
Tue Jan 25 23:22:32 PST 2005
    $layers = $map->getLayersIndexByGroup('IGBP_MOD12Q1');
    if ($layers) {
    while ($lr = each($layers)) {
        $oCurrLayer = $map->getLayer($lr[1]);
        $oCurrLayer->set( "status", 1);
       this line might be needed if you have done $map->draw() allready
:  $oCurrLayer->draw( $image);
>Hi,
>I am able to customize the GMap php-rosa sample app. I have the
>following layer in my .map file, I am using TILEINDEX for 8km and 1km
>resolution and for the top level 50 km I am using tif image. In by JBox
>I used to call this layer by the GROUP " MOD12Q1" and it worked, now in
>the php application how do I call this group? Is there similar method
>call like getlayerbyname() for LAYER GROUP?
> $poLayer = $gpoMap->getlayerbyname("IGBP_MOD12Q1");
> $poLayer->set("status", 1);
>Returns
>Warning: getLayerByName failed for : IGBP_MOD12Q1 in
>f:\Inetpub\wwwroot\gmap\htdocs\gmap75.inc.php on line 116
>Any suggestion would be highly appreciated Thanks!
>Giri
>Here is my layer snippet from the .map file
>LAYER
>  NAME IGBP_50k
>  GROUP IGBP_MOD12Q1
>  TYPE RASTER
>  DATA LL_SDS01GR50.tif
>  STATUS ON
>  MINSCALE 1490000
>  MAXSCALE 190000000
>  #MAXSCALE 10000
>  PROJECTION
>        "proj=longlat"
>        "ellps=GRS80"
>        "no_defs"
>  END
>END
>LAYER
>  NAME IGBP_8K
>  GROUP IGBP_MOD12Q1
>  TYPE RASTER
>  STATUS ON
>  TILEINDEX "modis_8km"
>  TILEITEM "Location"
>  MINSCALE 29000000
>  MAXSCALE 150000000
>  PROJECTION
>        "proj=longlat"
>        "ellps=GRS80"
>        "no_defs"
>        "proj=eqc"
>  END
>END
>LAYER
>  NAME IGBP_1K
>  GROUP IGBP_MOD12Q1
>  TYPE RASTER
>  STATUS ON
>  TILEINDEX "modis_1km"
>  TILEITEM "Location"
>  #MINSCALE 8000000
>  MAXSCALE 30000000
>  PROJECTION
>        "proj=longlat"
>        "ellps=GRS80"
>        "no_defs"
>        "proj=eqc"
>  END
>END
>Giri
More information about the MapServer-users mailing list
