projection doubts
Jeff Portwine
jdport at VERITIME.COM
Wed Jan 26 08:20:19 EST 2005
As you said, the projection in each layer is the "input" projection, or the projection that has been applied to the data in that layer. The projection block in the "map" section is the "output" projection, or the projection you will apply to your entire map for viewing. Mapserver does projections on the fly.
Hope that helped,
Jeff
----- Original Message -----
To: MAPSERVER-USERS at LISTS.UMN.EDU
Sent: Wednesday, January 26, 2005 4:16 AM
Subject: [UMN_MAPSERVER-USERS] projection doubts
Hi to all,
in a .map file the projection that apears in every layer is obiously the projection of that layer.
But what does the projection that apears before any layer in a .map file stand for?
Thank you
Jose Luis
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050126/9076852b/attachment.html
