[Mono-list] Re: Mono-list digest, Vol 1 #2293 - 14 msgs
Abe Gillespie
agillesp at VT.EDU
Wed Jan 26 10:46:32 PST 2005
I think what you're looking for is linked off of this page:
http://www.mono-project.com/contributing/resources.html
-Abe
On Jan 26, 2005, at 1:25 PM, Marte Castro wrote:
> hi,
> is this link http://www.go-mono.com/class-status-System.Data.html
> still accurate? if not, where cand i find the correct progress(status)
> of ADO.NET?
> Regards!
> mono-list-request at lists.ximian.com wrote:
> Send Mono-list mailing list submissions to
> mono-list at lists.ximian.com
> To subscribe or unsubscribe via the World Wide Web, visit
> http://lists.ximian.com/mailman/listinfo/mono-list
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> mono-list-admin at lists.ximian.com
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Mono-list digest..."
> Today's Topics:
> 1. Re: Web Services and native shared objects:
> System.DllNotFoundException (Jonathan Pryor)
> 2. RE: Bitwise operation weirdness (Mike Welham)
> 3. Re: monoLaunchW (Vincent Arnoux)
> 4. Paradox table access? (Morten Schmidt)
> 5. Re: Bitwise operation weirdness
> (=?ISO-8859-1?Q?Miquel_Ram=EDrez?=)
> 6. Re: monoLaunchW (Francisco T. Martinez)
> 7. Re: Basic Glade# question (Jonas Geiregat)
> 8. Re: monoLaunchW (Vincent Arnoux)
> 9. Re: ASP.NET on Linux: apache, mono, xsp, mod_mono (Jonas
> Geiregat)
> 10. Re: ASP.NET on Linux: apache, mono, xsp, mod_mono (Jonas
> Geiregat)
> 11. CVS Repository for Npgsql (Howard Cole)
> 12. Re: CVS Repository for Npgsql (Francisco Figueiredo Jr.)
> 13. Re: Basic Glade# question (Ian Parish)
> --__--__--
> Message: 1
> Subject: Re: [Mono-list] Web Services and native shared objects:
> From: Jonathan Pryor <jonpryor at vt.edu>
> To: Miquel =?ISO-8859-1?Q?Ram=EDrez?= <mvorkosigan at gmail.com>
> Cc: mono-list at lists.ximian.com
> Date: Tue, 25 Jan 2005 06:51:26 -0500
> On Mon, 2005-01-24 at 22:06 +0100, Miquel RamÃrez wrote:
> PS: I solved the logging issue (to some extent) by relying on log4net
> [ http://logging.apache.org/log4net ]. Better than having
> Console.WriteLines all over the place ...
> PS2: Also tried the <trace> feature in the web service 'descriptor'
> but it just traced the messages passed forth and back the server :(
> A built-in alternative to log4net is System.Diagnostics.Trace.
> See:
> http://lists.ximian.com/archives/public/mono-list/2004-January/
> 017482.html
> http://lists.ximian.com/archives/public/mono-list/2002-December/
> 010504.html
> http://www.go-mono.com/docs/index.aspx?tlink=9@ecma%3a1224%23Trace%2f
> tlink=9 at ecma%3a1182%23DefaultTraceListener%2f
> - Jon
> --__--__--
> Message: 2
> Subject: RE: [Mono-list] Bitwise operation weirdness
> Date: Tue, 25 Jan 2005 14:30:22 +0200
> From: "Mike Welham" <mike at digitalnova.co.za>
> To: <mono-list at ximian.com>
> Hi Miguel,
> bitwise.cs(11) error CS0029: Cannot convert implicitly from `int' to=20
> `short'
> Compilation failed: 1 error(s), 0 warnings
> If I do not misunderstand the compiler message, it seems that for some
> reason the result of or-ing together the hiword and the loword=20
> variables results in an 'int' (32-bit integer number, I suppose).
> The compiler is implicitly converting the two r-values to ints prior
> to =
> doing to doing the 'or', and then complaining about trying to
> implicitly =
> convert the resultant int to a short.
> There is no predefined C# 'or' for shorts, and the best match is the =
> 'or' for ints. See the C# spec quotes below.
> Why is that? It is easily fixed by explicitly casting the result of=20
> the bitwise or operation down to a short, but I can't help feeling=20
> that this feels weird: is it a C# specification feature?
> The C# spec says:
> <spec section 14.10>
> For an operation of the form x op y, where op is one of the logical =
> operators, overload resolution (=A714.2.4) is applied to select a =
> specific operator implementation. The operands are converted to the =
> parameter types of the selected operator, and the type of the result
> is =
> the return type of the operator.
> </spec>
> And=20
> <spec section 14.10.1>
> The predefined integer logical operators are:
> int operator &(int x, int y);
> uint operator &(uint x, uint y);
> long operator &(long x, long y);
> ulong operator &(ulong x, ulong y);
> int operator |(int x, int y);
> uint operator |(uint x, uint y);
> long operator |(long x, long y);
> ulong operator |(ulong x, ulong y);
> int operator ^(int x, int y);
> uint operator ^(uint x, uint y);
> long operator ^(long x, long y);
> ulong operator ^(ulong x, ulong y);
> </spec>
> Best Regards
> Mike
> --__--__--
> Message: 3
> Date: Tue, 25 Jan 2005 13:41:33 +0100
> From: Vincent Arnoux <vincent.arnoux at rfo.atmel.com>
> To: mono-list at lists.ximian.com
> Subject: Re: [Mono-list] monoLaunchW
> Paolo Molaro a =E9crit :
> On 01/24/05 Vincent Arnoux wrote:
> =20
> I am looking for launching a Gtk#/Mono application on Windows
> without=20
> displaying the "not very sexy" DOS window.
> =20
> Compile the app with the -target:winexe mcs option.
> I didn't test it, but it's supposed to work.
> lupus
> =20
> I used the w32 installer and it didn't work, believe me. I don't know
> where to find sources to recompile it. When I try to run monolaunchW
> myapp.exe, I get a "Cannot find mscoree.dll" error message. If I
> download this dll from Internet and retry, I get something like ".NET
> is
> not correctly installed" message.
> Vincent
> --__--__--
> Message: 4
> Date: Tue, 25 Jan 2005 14:14:05 +0100
> From: "Morten Schmidt" <sch at knowledgelab.sdu.dk>
> To: <mono-list at lists.ximian.com> ,
> <mono-list-request at lists.ximian.com>
> Subject: [Mono-list] Paradox table access?
> --=__Part94B42E0D.0__=
> Content-Type: text/plain; charset=US-ASCII
> Content-Transfer-Encoding: 7bit
> I'm not sure this is the place to ask, but here goes nothing:
> Anyone jnow anything abaout accessing Paradox Tables in an easy
> fashion,
> ie. directly/ODBC/ADO or what-ever?
> thanks... Just point me in the direction of a few pages on the
> subject...
> /morten
Name: not available
Type: text/enriched
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050126/7cace49f/attachment.bin>
More information about the MapServer-users
