RES: [UMN_MAPSERVER-USERS] php extensions
Murilo Lacerda Yoshida
murilo.yoshida at AGX.COM.BR
Wed Jan 26 16:44:24 EST 2005
Paul,
The extension directory is set on the extension_dir variable on
php.ini.
I don't remember exactly, but I guess that the php installation
doesn't create this directory. You have to create one and then set the
extension_dir to this directory, and then put your extensions in it.
About gd, you can run configure --with-gd, and that will create the
php binary with the gd extension in it.
If you use extension = <extension>.so, the extension has to be in the
extension directory.
Hope that helps,
Murilo
-----Mensagem original-----
De: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] Em
nome de Paul Smith
Enviada em: quarta-feira, 26 de janeiro de 2005 17:29
Para: MAPSERVER-USERS at LISTS.UMN.EDU
Assunto: [UMN_MAPSERVER-USERS] php extensions
Hello All
I could do with help installing php. After running the configure script,
I
can't seem to find the extensions directory. I have read and re-read the
INSTALL file in the php distrib. I'd like to add extensions using the
extension = gd.so
Is it still necessary? If I run phpinfo() I don't see gd for instance.
php_Mapscript is there.
Where and how do I add extensions? Any help would be appreciated.
Paul
System
SUSE Linux Ent Server 9
Mapserver 4.4.1
php-4.3.10
gd-2.0.33
Apache 2.0.52
